RedMist wrote:And Toyota backed the series.
and that i bet is the main reason....
Just because there is a race series dedicated to a certain brand/model/engine dosnt mean its the best...
otherwise we would all be driving HQ holdens.....
Defective wrote:RedMist wrote:And Toyota backed the series.
fivebob wrote:Defective wrote:RedMist wrote:And Toyota backed the series.
No the reason is that Formula Atlantic/Formula Pacific was a spec motor series. The BDA Ford was getting past it's use by date and Toyota stepped up to the mark and supplied an execellent replacement engine in the form of the 4A-GE.
Defective wrote:fivebob wrote:Defective wrote:RedMist wrote:And Toyota backed the series.
i guess we're just lucky MG or lada didnt decide to sponser it then.....
Mr Revhead wrote:yeah the amercians have certainly embraced the b16a.. hence the large parts avail for it.
if toyota had chosen to sell the 4age in as many models as honda did the b16a youd see the same thing with that.
Mr Revhead wrote:Defective wrote:Mr Revhead wrote:if toyota had chosen to sell the 4age in as many models as honda did the b16a youd see the same thing with that.
sh*t, i would have thought the 4AGE was in more models than the B16A....
not in america, the b16a was a far more mainstream engine than the 4age
RedMist wrote:Longer Rods
The rods are longer 132mm as opposed to 123mm for the 4age. It allows the piston to sit at almost TDC for longer. This in theroy is supposed to build more pressure and more power. It also doesnt provide as much side angular thrust on the pistons, as such you can run a smaller piston skirt.
Erelyes wrote:Wouldn't this mean that the 4AGE has a shorter stroke,
BWDOWN wrote:I'm Honda biast sure but at least I can appreciate a good engine when I see one, as I have done in all cases..
Mr Revhead please... your are one of the most biast people I have ever seen on a forum and even when people produce facts you choose to ignore them and try hunt down more info. Why cant you just face facts???
B16A>any 4AGE
/end story
