MSII on silvertop.
MSII on silvertop.
Postby ChaosAD » Thu Jun 07, 2007 6:48 pm
Is anyone on here running an ms-II megasquirt ecu on their silver or blacktops?
ChaosAD
Postby slighty_sykotic » Sat Jun 09, 2007 8:21 pm
Used to run a ms I (at least im sure it wasnt a ms II....) if thats anyhelp?
slighty_sykotic
Postby ChaosAD » Sun Jun 10, 2007 12:13 am
Do you still have your old maps? im setting one up but it would be a lot easier with base maps to start with.
Where did you take the vacum signal from? and did you need any form of signal damper to smooth out the spikes?
ChaosAD
Postby slighty_sykotic » Tue Jun 12, 2007 10:28 am
Sorry, I've had a really good look over the weekend for the maps, and I can't find them. Sorry.
I took the vaccum from the fuel pressure regulator. Probably not the best, but the signal was stable from what I could see and it ran fine.
slighty_sykotic
Postby spencer » Tue Jun 12, 2007 11:06 am
http://www.msruns.com/viewforum.php?f=89
used the blacktop map thats available there to start mine ages ago. never got it tuned though. Also theres a few 20v guys there pm them if your keen.
ms63 crown
spencer
