head off 4age
head off 4age
Postby westwayz » Thu Jun 07, 2007 3:24 pm
what tool to i need to take the head off a 4age i can see 4 hex type but dont know wat size and is that the onlything holding the head down?
[ KE70 - 20v Dori'O Machine ] - In the build
westwayz
Postby ~SlideWays~ » Thu Jun 07, 2007 3:35 pm
10mm socket from memory, maybe a 12.
~SlideWays~
Postby Boosted_162 » Thu Jun 07, 2007 3:40 pm
viewtopic.php?t=38883
That should be of some help.
Postby pc » Thu Jun 07, 2007 4:47 pm
10mm on a 16valve
looks like a star, so a normal 12 point socket.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Mr Revhead » Thu Jun 07, 2007 6:17 pm
yeah 16v are a normal bolt head
20v an internal socket thing
koken to the perfect part 8)
Postby l1ttle_d3vil » Thu Jun 07, 2007 10:21 pm
yep, 10mm hex socket. just pull the cams out then take those bolts off. you're supposed to do it in a particular order though. either from the middle outwards, or start at the outside and work your way in. just go thru and crack each bolt off, then undo them say 1/4 turn, then go through and loosen them all off a bit more, then fully off. that way it can prevent the head warping. not sure how common it is, but thats just waht I was told.
someone can confirm whether you start with the middle bolts or the outside ones though...?
i pulled one off for the first time a few weeks back and they're easy to take off, might just need to give it a bit of a pull to separate it from the block though...
cheers.
Postby westwayz » Sun Jun 10, 2007 9:39 pm
so do i have to pull the cams out? 8O damn it!
westwayz
Postby l1ttle_d3vil » Sun Jun 10, 2007 9:57 pm
try it with them still in, but you might find it a bit hard to get the socket down there...
