big_boy wrote:its simple if you have a bigger spinning mass then it takes alot more effit to stop it this effit is relayed in to extra torque
when you do a motor up & put a lighter fly wheel on you gain HP by revs but loose tork altho you then make it up with the revs
say with a std 3L motor with a 12kg flywheel you have 200nm @ 3000rpm
then say the same 3L motor with a 5kg flywheel may only have 130nm @ 3000rpm
but alt the same time will rev to maby 7500rpm insted of 6500rpm its all about shifting your power to were you want it
the lighter flywheel will have more HP at say 6000rpm than the heaver tho
it just depends were you want power
frost wrote: up hill with light weight flywheel is fun....not
Punter wrote:The way I look at it (makes sense in my head)
Is that the flywheel can't have an effect on power or torque when the engine is at a fixed speed.
Yes the flywheel acts as a,... well, flywheel.frost wrote:but the load IS the flywheel its the gyro(sp) that keeps everything spinning
You didn't read the last line of my post thenbig_boy wrote:Punter wrote:The way I look at it (makes sense in my head)
consent speed & load correct but unless were talking about pump motors witch i dought this therid was made for then they do make a big difference
big_boy wrote:accually this is tru
a lighter fly wheel will give you less torque but will rev quicker & higher
a heaver fly wheel will give more torque dew to the fact as it takes more effit to stop it spinning but will also take longer to rev up & will be harder to get to spin as fast
Grrrrrrr! wrote:Maybe one of the Mods would like to sticky this?
Users browsing this forum: No registered users and 37 guests
