Tempature gauge going crazy
Postby Zyros » Sun Jun 17, 2007 11:47 pm
Hey, my GF's car was having issues today.
The temp gauge would go up to hot, then within a minute down to noarmal, then up to hot, then down to noarmal etc..
When it was on Hot (red) i popped the bonnet and the engine seemed to be at noarmal running tempature..
Radiators sweet, no cracked hoses and coolant levels sweet.. Any idea's?
I was thinking either then Fan (if it would do that?)
Temp sender
Theromstat?
Zyros
Postby Calvin » Sun Jun 17, 2007 11:48 pm
faulty thermostat/temp sensor id say.. going on the assumption your observations are correct and motor is sweet
Calvin
Postby gepsk8 » Mon Jun 18, 2007 12:19 am
what car?
when u check the coolant last before the problem?
sounds like it needs to be bleed up propably get the air out of the sytsem
gepsk8
Postby MrOizo » Mon Jun 18, 2007 10:52 am
check that the wire is actually hooked onto the sender and its not grounding anywhere else..
MrOizo
Toyspeed Legend
Postby Zyros » Mon Jun 18, 2007 5:32 pm
Honda civic 1993 sedan,
It deffinatly not over-heating, i thought if it was the theromstat, the car would actually overheat?
Zyros
Postby gmacrae » Tue Jun 19, 2007 1:18 pm
or just bubbles in the system?
to burp the coolant some cars want the front raised up a bit, then idle with the cap off for a while, tapping the gas a bit, if you notice the level goes down there was a bubble in there - could explain it.
gmacrae
Postby sergei » Tue Jun 19, 2007 1:27 pm
hondas have special nipple to remove air from the system on the coolant elbow on the head.
