ST210 headlight bulb!
Postby ~KDL~ » Mon Jun 18, 2007 1:33 pm
I'm well confuddled... I can't change out a damn bulb from the headlight in a '99 Caldina... How the heck do the clips come undone? And what bulbs are required for the replacement?
Everybody makes mistakes. Champions never make the same mistake twice.
~KDL~
Postby eskimo » Mon Jun 18, 2007 1:40 pm
I think the come out from the back should be locking cap at the abck then you can get to the bulb from there, correct me if im wrong thoe.
The bulb will be h1, h3 or sumthing h , it will be stamped on the base of the bulb.
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby ~KDL~ » Mon Jun 18, 2007 1:48 pm
huh?
I know it comes out the back! there is usually a metal type clip that holds a bulb in the headlight assembly which you clip off and to the side, but I can't get this one to work so simply!
Driving me nuts!
~KDL~
Postby jakelanauze » Mon Jun 18, 2007 8:46 pm
had same trouble with my ST215, its held in by a clip, and its a bastard to get out.
jakelanauze
Users browsing this forum: Bing [Bot] and 28 guests
