deaf_rattle wrote:and coolant lines (being an ae82 the radiator has the hoses in the right place, so run the 20v radiator hoses)
ChaosAD wrote:So does the silvertop engine mount fit the ae82 chassis? or should I use the ae82 engine mount and braket?
Will the 20v extractors fit the 16v 2>1 section?
ChaosAD wrote:Cool, so the engine mount bolts onto the block no worries?
Might need to silicon up the hole in the cambelt cover if the mount is a different shape.
Distrb wrote:deaf_rattle wrote:and coolant lines (being an ae82 the radiator has the hoses in the right place, so run the 20v radiator hoses)
Err not completely
The bottom tank of the radiator is in the right place, the top one isnt and needs a custom hose made up (i made one by chopping up the 16v hose that winds its way around the cam belt covers and to the water pump, ask gurutasker if you want pics as its in his car now)
You can fit a 20v radiator in and use the factory hoses, but you have to cut the lower mounts and reweld them on a little further down the rad support panel, otherwise you wont be able to close the bonnet. Also its worth realigning the top brackets to match up with the new radiator...ChaosAD wrote:So does the silvertop engine mount fit the ae82 chassis? or should I use the ae82 engine mount and braket?
Just use all the mounts and brackets from the ae82 and it will bolt in perfectly
I wouldnt think the 20v extractors would match up to the lower 16v section (i've never tried it myself), but give it a go and see if it works for you
deaf_rattle wrote:errr wrong![]()
what i said is what i did, i used the ae82 radiator as bought from pete THA SHZ
and used 20v hoses.
everything was fine.
Maybe you used a non 4age ae82 radiator?
I dont know, but dont go saying people are wrong when they are talking from experience.
Sounds like there maybe different ae82 radiators
bluemaumau wrote:hey dude are all rb20det boxes the same? i.e are laurel boxes the same as skylines?
