4agze wireing
4agze wireing
Postby raddies » Tue Jun 19, 2007 1:29 pm
howsit, have just bought MAP senserd 4agze out of an AE92 which i am in the process of turbing an throwing in my allready 4-age rwd corolla,(am not keeping supercharger, replacing with tvis maniflod etc) so i have my old bluetop for rwd parts and compnents etc.
Thing is the ze did not come with coil packs or leads etc, have heard my bluetop dizzy would work fing to spark the ze, was wondering then what model ze ecu and loom would i require to then wire it up?, as a coil type ecu wouldnt do the job would it? as dont have enough coin for lnk etc (student) any help wud be sweet cheers
raddies
Postby gmacrae » Tue Jun 19, 2007 2:13 pm
Sorry i cant answer your wiring question, but you're gonna have a problem trying to use your tvis intake mani on that smallport GZE, you're gonna need to find a smallport intake manifold and cut/swap the throttle to the other end.
gmacrae
Postby slighty_sykotic » Tue Jun 19, 2007 4:44 pm
afm and dizzy 4agze ecu.
Like the aw11 mr2 4agze.
I have an ecu somewhere, but no loom.
slighty_sykotic
Postby raddies » Tue Jun 19, 2007 4:59 pm
but my ze is MAP sensord not AFM
raddies
Postby gepsk8 » Tue Jun 19, 2007 7:30 pm
get some coils of trademe or bosch do twin tower coils and get some leads, get it wired in and ur away.
or
what kind of boost u wana be running? its almost cheaper to fit a link, then u can run the boost u wana run not limted to 14psi. still need coil/s tho
gepsk8
Postby raddies » Wed Jun 20, 2007 1:28 pm
yeah will prob run jst 4agze ecu as dont have enough coin for a link or tuning it etc, yer wont run anything around 14psi will prob run 10 or 11 psi as running rb20 turbo anyway (dont wana brake it),
raddies
