Smallport 4age with quads- question.
Postby HachirokuGTV » Fri Jun 22, 2007 12:09 am
If you use 20v quads either black or silvertop (yes i know there is a difference) with a redtop smallport, what loom do you use? What ecu can you use? Is there anything else that needs changing?
HachirokuGTV
Postby bluemaumau » Fri Jun 22, 2007 12:10 am
i assume your going to be running trumpets?
if so the blacktop loom is MAP sensored so its the way to go
i dont know how compatible it is with smallport loom tho sorry
Postby ChaosAD » Fri Jun 22, 2007 8:18 am
Id use the smallport loom and fit the smallport tps to the quads.
Then use an aftermarket ecu such as a link
ChaosAD
Postby QikStarlie » Fri Jun 22, 2007 11:18 pm
yeh, but dont fit the smallport tps to the quads. as the tps is back to front. just use the 20v one. plug is the same. the new link g3's are awesome for running quads. long as whoever sets it up knows what they are doing.
dont bother trying to use a standard ecu to run them either
QikStarlie
