x member swapping
x member swapping
Postby d1 mule » Mon Jun 25, 2007 6:27 pm
does anyone no if a cross member out if a JZX81 will fit into a GZ10 soarer???
and do JZX81 1jz use the front of rear sump as i have a rear and cant find a front to if the X81 is rear sump and will fit innthe Z10 that saves so much pissing about
cheers guys
d1 mule
Postby postfach » Mon Jun 25, 2007 6:33 pm
jzx81 has the rear sump, but i think the z10 soarer shares parts with the ma61 etc, z20 is g/jzx81 and g/m/jza70
postfach
Postby spencer » Mon Jun 25, 2007 6:41 pm
jzx81 is front sump can go take a pic if you need proof
ms63 crown
spencer
Postby postfach » Mon Jun 25, 2007 8:08 pm
ke70wagon20v wrote:jzx81 is front sump can go take a pic if you need proof
i thought the jzx81 crossmember was the same as the jza70 one though? and on the jza70 the deep part of the sump is most definitely at the back, i had a mid sump engine from a jzx90 and had to change to a rear sump to clear the crossmember in my z20
postfach
Postby spencer » Mon Jun 25, 2007 9:12 pm
um nope supra has steering at the front due to the arm setup of the front suspension. jzx81 has the sump at the front and the steering rack at the back I have one sitting on a jzx81 member in the shed now
ms63 crown
spencer
Postby d1 mule » Mon Jun 25, 2007 10:55 pm
dont suppose ya wanna swap plus cash for a complete mid/rear setup?? :D
d1 mule
Postby spencer » Tue Jun 26, 2007 8:26 am
not at the moment as it suits my purposes
ms63 crown
spencer
Postby d1 mule » Tue Jun 26, 2007 11:58 am
sweet so can you possibly tell me which model cars front sump 1JZ came out in? and so they have to be "turbo" sumps to go on the turbo engine thanks heaps
d1 mule
