fitting the $&#$% cv's back into a ae90?????
Postby tsoob » Tue Jun 26, 2007 2:25 am
i have been in the shed all night with a mate trying to get the cv's back into the box, and have had no oy pleanty of swearing and skin lost from fingers, is there a trick to getting the splines into the box? it is about the lat 30mm to go on the passanger side but we cant get it fully in.
Nick
tsoob
Postby bluemaumau » Tue Jun 26, 2007 9:48 am
are you using the right shafts and box?
Postby 85AW20v » Tue Jun 26, 2007 10:36 am
And on the correct sides? They can be different.
See ya
Simon
85 MR2 20v
85AW20v
Postby tsoob » Tue Jun 26, 2007 10:38 am
yes it is the ones that were in the car pre motor removal, i just cant get them to go the last 30mm, we tried to bash it while i hold it in place and that just hurt my hand and the joint poped out again?? thanks.
tsoob
Postby Ae92typeX » Tue Jun 26, 2007 12:49 pm
is the circlip actually going in, or is this the point at which it is getting stuck? (often this can be an issue. Ive found positioning it correctly with some grease helps)
Ae92typeX
Postby Bling » Tue Jun 26, 2007 6:10 pm
tsoob wrote:we tried to bash it while i hold it in place and that just hurt my hand and the joint poped out again?? thanks.
try connecting it to the hub and push on the hub, less pain ;)
Postby tsoob » Tue Jun 26, 2007 9:18 pm
the hub is connected to the cv, the circlip is on the end of the spline, it was in the box and it come out on the spline do i stick this back into the box? does this job usually involve bashing the hub?
thx
tsoob
Postby Lloyd » Tue Jun 26, 2007 10:12 pm
Usually easiest to get it most of the way in and have the outer CV in the hub with the bottom ball joint not in, then give give it a swing so the weight of the hub pushes on the drive shaft and pops the inner CV into place.
Failing that, get someone to hold the hub out of the way (without the outer CV in it) and line the driveshaft up with the inner CV so you're trying to push straight into the box, hold the inner CV in place and give it a push so the inner CV goes into itself and hits the CV into place (if you get what I mean).
Failing that, hold the shaft in line as above and bash the outer CV with a hammer until it goes in :) Being careful not to damage the outer CV of course, otherwise it migth be hard to get the nut back on
Postby fangsport » Tue Jun 26, 2007 11:33 pm
Ae92typeX wrote:is the circlip actually going in, or is this the point at which it is getting stuck? (often this can be an issue. Ive found positioning it correctly with some grease helps)
yip, and check to see if the circlip has been damaged in previous attempts to insert the CV. often the end will curl a wee bit if you try to get too forceful.
fangsport
Postby z0ton » Tue Jun 26, 2007 11:42 pm
Im having exactly the same problem with my passengers side one as well. The first bit goes in but the last bit just wont go in. Ive tried doing it for hours. I think the circlip is a bit out of shape or something..
z0ton
Postby tsoob » Wed Jun 27, 2007 8:15 pm
$&#$% cv's are in
tsoob
Postby Crucible » Wed Jun 27, 2007 11:45 pm
z0ton wrote:Im having exactly the same problem with my passengers side one as well. The first bit goes in but the last bit just wont go in. Ive tried doing it for hours. I think the circlip is a bit out of shape or something..
should only take a soft tap to get it in, if you are bashing the fu*k out of it something aint right. if the circlip jams it will burr the splines. Then you have to dress it up with a file and fit a new clip.
Crucible
Real Life Mechanic
Postby tsoob » Thu Jun 28, 2007 10:11 am
WE ENDED UP LINING IT UP BY HAND THEN USED A LONG SCRWDRIVER TO TAP IT HOME NOT HARD JUST GENTLE TAP.
tsoob
Users browsing this forum: Bing [Bot] and 12 guests
