fuzzilogyc wrote:yup, absolutely... its good as gold now...
dunno if this is related, but car blows a lot of white smoke when its cold and even more when the weather's cold. the problem's not so bad when its a warm day... any1 got any ideas?
fuzzilogyc wrote:but its quite a lot... like one cold night, i started the car, waited 2 or 3 mins and revved it a little for a while and it basically blanketed the car behind me. I haven't seen it that bad since... but yeah.... its still a lot more than most cars...
fuzzilogyc wrote:umm the smoke was white though - same as water vapour - not grey or blue or anything...
i'm guessing air/fuel is off cos i've got shitty fuel consumption - my guess being that the O2 sensor is bung - need to check.
dunno if there are any faults coming from ECU, how do you check?
the motor's on 193,000 kms
fuzzilogyc wrote:yeah might be a combination of leaky head gasket and rings...
motor is a bit tired now, i don't think its ever had a rebuild in its life...
might see if i can find myself one of these manuals, cheers
