postfach wrote:did you do a full exhaust from the turbos back? if you replaced the factory downpipe you will definitely overboost and without the boost cut you'll kill your turbos pretty quickly, they have a ceramic exhaust wheel and it falls off at around 16psi (boost cut is 14ish)
if you did replace the downpipe, i suggest putting some kind of restriction in the exhaust, perhaps a sheet of metal between 2 flanges with a 2.5" hole in it or something
the fallen303 wrote:it's funny people saying that the turbo's die above 1bar... mine have been running stable at 16+for 10 years of very hard driving, and they're still fine. running with custom 3" dumps and straight through 2 3/4 exhaust, no mufflers.
oh well, it works *shrugs* just talking to dad, it's a zener diode, sorry, i thought it was a resistor from a conversation we had about it a few years back, memories shot, lol. dad says it's to allow about 4.7 volts? if that makes sence to anyone.
Crampy wrote:Yep, now that makes a whole lot more sense.
If you use a zener diode rated at 4.7 volts it'll stop the voltage going higher than that.
You need to put it reverse biased and shunt it to earth. that way the MAP sensor voltage will remain normal up until the Zener voltage, above that the voltage is clamped at the zener voltage as the extra current is shunted to earth. Wahlaaa a voltage clamp.
An avalanche diode will do the same thing, provided you can get one rated to the correct voltage.
From the internet:
A common application is protecting electronic circuits against damaging high voltages. The avalanche diode is connected to the circuit so that it is reverse-biased. In other words, its cathode is positive with respect to its anode. In this configuration, the diode is non-conducting and does not interfere with the circuit. If the voltage increases beyond the design limit, the diode suffers avalanche breakdown, causing the harmful voltage to be conducted to earth. When used in this fashion they are often referred to as clamper diodes because they "clamp" the voltage to a predetermined maximum level. Avalanche diodes are normally specified for this role by their clamping voltage VBR and the maximum size of transient they can absorb, specified by either energy (in joules) or I2t. Avalanche breakdown is not destructive, as long as the diode is not allowed to overheat.
