Levin BZG AE111 4age using oil
Postby lost247 » Thu Jul 05, 2007 12:15 pm
Hi I have a Levin BZG Ae111 4age blacktop.
I Have recently havin problem with it using oil
Is not smoking only a little wen hitting hi revs.
And its not leaking anywhere.
Last time i gave it a service in 2000k it has used almost all of its oil.
It just seems to be eating it.
I used shell ultra full synthetic. i an now at 10000k and its used all of another oil container 4L. The engine seems to be fine no probs there. I am just wondering if its not liking full synthetic oil should i change to semi. If so which brand would be the best.
Any Help would be great
thanks
lost247
Postby ChaosAD » Thu Jul 05, 2007 1:29 pm
What grade are you using?
ChaosAD
Postby Voyeur » Thu Jul 05, 2007 1:47 pm
They are well known for using oil, no matter what grade you use. My black top uses about 500ml per 1000k, so it is about the same as yours. I have found that magnatec gives me the best milage, where as mobil 1 was about 700ml per 1000k. Every body seems to recommend to keep the oil in the 20-40 20-50 range so it would seem, as long as it's not pouring smoke out the back, and fouling your oxy sensors, it cant be that bad.
Voyeur
Postby B1NZ » Thu Jul 05, 2007 7:40 pm
I had this problem in my old one, Wasn't smoking or anything but was using about a litre a week :oops:
Turned out to be the oil control rings, Compression was fine but was getting blow by So I'm guessing yours is along the same lines, If you get the rings replaced and the Bores ok, put a new set of bearings in at the same time
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby lost247 » Fri Jul 06, 2007 11:17 pm
Cheers thanks 4 the help.
Do you know how much that would cost
Thanks
lost247
Postby B1NZ » Sat Jul 07, 2007 5:26 pm
Cost me all up including parts about $1500 for memory, may have been a bit cheaper but it was a while ago, Depends on condition of the engine, NBest to take it somewhere to get it assessed
Subaru GF8 Wagon
B1NZ
Users browsing this forum: Bing [Bot] and 18 guests
