installing manual boost controller on mr2,,,
Postby 92mr2paddy » Fri Jul 06, 2007 6:00 pm
ok,, boost hasnt been touched yet,, i got a manual boost controller, got inlet/outlet and a screw on top to adjust boost (aranged in a "T" shape, also dont know what u should do with the bottom outlet) .. but where do i install it and do i need to remove any factory boost solenoids etc and if so how??
92mr2paddy
3sgte VSV info
Postby Mr Revhead » Fri Jul 06, 2007 6:14 pm
whooopss :oops:
Postby 92mr2paddy » Fri Jul 06, 2007 6:16 pm
umm ???? haha does that mean i have to remove the VSV (whatever that is)? :roll:
92mr2paddy
Postby Mr Revhead » Fri Jul 06, 2007 6:18 pm
oops... dont mind me... clicked reply instead of new post!! :lol: :oops:
Postby Dell'Orto » Fri Jul 06, 2007 7:11 pm
Put it in the wastegate line, which is the one from the compressor housing to the diaphragm on the side. Block off the other line from the diaphragm at both ends of the line.
Leave your boost cut in until you get it sorted properly!
Postby 92mr2paddy » Fri Jul 06, 2007 7:14 pm
hey, cheers for that,
i still not sure about the third side of the controller, it got in and out then in the middle it got another smaller pipe coming off? does this need to be blocked of or plugged in somewhere else?? cheers pat
92mr2paddy
Postby Dell'Orto » Fri Jul 06, 2007 7:17 pm
Without seeing what boost controller it is I can't really say.
Postby 92mr2paddy » Fri Jul 06, 2007 7:22 pm
haha its an el cheapo
heres a link with picture
http://broomfish.co.nz/popup_image.php?pID=476
thanks for the fast help
92mr2paddy
Postby Dell'Orto » Fri Jul 06, 2007 7:25 pm
Ah right, that looks to be where it bleeds off boost pressure. So blocking it off would negate having a boost tap :lol:
Postby 92mr2paddy » Fri Jul 06, 2007 7:28 pm
mmm? block it of then?? and join inline with the wastegate line??,,
92mr2paddy
Postby slonlo » Fri Jul 06, 2007 8:55 pm
leave it open
if you block it the boost tap will do nothing(eg you will be running factory boost still)
'89 LiteACE van
slonlo
Postby 92mr2paddy » Fri Jul 06, 2007 8:57 pm
yea cheers, i just found that out as i drove car with it closed then open and finaly got it sussed,
thanks guys :lol:
92mr2paddy
Users browsing this forum: Bing [Bot] and 25 guests
