4agze Flooding
4agze Flooding
Postby z0ton » Sun Jul 08, 2007 9:18 pm
I'm currently trying to get my 4agze going but having a bit of trouble starting it up...
Theres a few pics of it here : viewtopic.php?t=57706
I'm getting fuel and spark but it flooded real bad (there was like a cm of fuel on top of the pistons :().
Anyone know why it would do that? I'm getting the impression that my injectors are possibly stuffed but what are the chances of all 4 stuffing out at the same time...
Any ideas?
z0ton
Postby l1ttle_d3vil » Sun Jul 08, 2007 9:42 pm
when you wired it up, did you accidently earth the injectors out constantly?
ive seen that happen before - the engine floods with fuel, then if you disconnect the pump or injectors and crank the engine over it slowly burns the fuel away until it can fire up then will run off the fuel thats in the bores until it runs out...
Postby z0ton » Sun Jul 08, 2007 9:57 pm
l1ttle_d3vil wrote:when you wired it up, did you accidently earth the injectors out constantly?
I'll check that tomorrow. We stopped the fuel coming through by turning off the pump and unplugging the injectors and it sure did burn it out. Flames came out the intake...
z0ton
Postby l1ttle_d3vil » Sun Jul 08, 2007 10:44 pm
sounds like your timing would be out too then, check that out properly too.
Postby z0ton » Mon Jul 09, 2007 11:38 pm
l1ttle_d3vil wrote:sounds like your timing would be out too then, check that out properly too.
Got it started tonight. Timing was out a few teeth and the main problem was 2 injectors are stuffed. Put some 4age ones in just to start it and it worked.
z0ton
Postby Allister S » Tue Jul 10, 2007 2:14 pm
Hey, Aren't GE and GZE injectors different resistances?? I had to use some ballast resistors to wire up my Link ECU.
Please correct if that's wrong.
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Postby z0ton » Tue Jul 10, 2007 6:44 pm
Allister S wrote:Hey, Aren't GE and GZE injectors different resistances?? I had to use some ballast resistors to wire up my Link ECU.
Yea thats true. I only ran it for a few seconds to make sure everything else was ok. Im getting some new ze injectors for it.
z0ton
Postby Ae92typeX » Tue Jul 10, 2007 6:52 pm
I believe it depends on which GE:
http://www.toysport.com/webpages/Techin ... ectors.htm
Ae92typeX
Postby Bazda » Tue Jul 10, 2007 9:09 pm
he is prob talking about 4age and 4agze.
Postby Ae92typeX » Tue Jul 10, 2007 9:27 pm
sorry, I should have worded differently:
according to the chart there are some low and some high resistance injectors for the ge, so some would be compatable with the ze
Ae92typeX
