The place for all technical car discussions. If you haven't already, read our
Disclaimer first!
lucasthefallen
Posts: 425 Joined: Tue Mar 01, 2005 7:02 am
Post
by lucasthefallen » Mon Jul 09, 2007 7:21 am
looing at buying an rs200, before i started having a good look at anything just wanted to find out wether or not any altezza's came lsd, and if so does anyone know the diff code??
Need Service or Repair work done? send me a PM
Dodgy Guy
Posts: 202 Joined: Thu Jul 08, 2004 10:04 am
Post
by Dodgy Guy » Mon Jul 09, 2007 8:02 am
chassis plate, the one on the firewall...
A01A - 3.916 ratio Open Centre
A01B - 3.916 ratio Torsen LSD
A02A - 4.083 ratio Open Centre
A02B - 4.083 ratio Torsen LSD
So the 'B' denotes LSD
TWSTD
Posts: 1922 Joined: Tue Oct 15, 2002 1:46 pm
Contact:
Post
by TWSTD » Mon Jul 09, 2007 1:03 pm
So whats an A03A then? As thats the code on my altezza...
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Contact:
Post
by TWSTD » Mon Jul 09, 2007 1:29 pm
Nope - AS300 4WD
Click here!
Ard Righ
Posts: 23 Joined: Tue May 15, 2007 1:49 pm
Post
by Ard Righ » Mon Jul 09, 2007 3:11 pm
TWSTD wrote: Nope - AS300 4WD
Your car will most likely have an entirely different setup then.
The LSD are mostly in the RS200 models from what I've seen so far, the newer models of IS300/AS300 etc will be different to what's listed in the thread.
Not sure anyone has much info on those models yet.
TWSTD
Contact:
Post
by TWSTD » Mon Jul 09, 2007 3:59 pm
Indeed they dont. Havin a real mare trying to find a possible gearbox for manual conversion.....
Click here!
lucasthefallen
Post
by lucasthefallen » Mon Jul 09, 2007 6:13 pm
Dodgy Guy wrote: chassis plate, the one on the firewall... A01A - 3.916 ratio Open Centre A01B - 3.916 ratio Torsen LSD A02A - 4.083 ratio Open Centre A02B - 4.083 ratio Torsen LSD So the 'B' denotes LSD
excellent! thank you very much
