Instructions for replacing Blacktop 4AGE big end bearings
Postby Timoz » Thu Jul 12, 2007 6:32 pm
Hi all, i need to replace my big end bearings and i wanna do it myself to save me a bit of money, i got a set of socket set. i just wanna know what are the steps to replace these bearings. it would be nice if someone can teach me in person :D
Timoz
Postby Rick » Thu Jul 12, 2007 6:38 pm
Postby B1NZ » Thu Jul 12, 2007 6:52 pm
Oh dear, have you done anything remotley like this before? Do you have anything other than a socket set? Is it a Repco $30 one? :oops:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Timoz » Thu Jul 12, 2007 6:57 pm
i've changed the air con and drive belts myself before, i can get more tools from my dad as he's a plumber. how much are the ACL race bearings for my blacktop anyway and where can i get them in Auckland?
Timoz
Postby rollaholic » Thu Jul 12, 2007 7:04 pm
you are going to want a torque wrench at the very least, which i dont think your dad will have unless hes also a mechanic.
i think its safe to say you'll be much better off paying someone else to do it.
Postby Timoz » Thu Jul 12, 2007 7:08 pm
how much approximately if i provide the parts?
Timoz
Postby AceSniper » Thu Jul 12, 2007 7:20 pm
ACL big ends are cheap from supercheap
def need a good torque wrench
Shouldnt cost tooo much at a workshop, unless your mains need doing to then ya mayaswell rebuild it
AceSniper
Postby ChaosAD » Thu Jul 12, 2007 7:45 pm
If your replacing them coz youve run a bearing then it needs a rebuild
ChaosAD
Postby Timoz » Thu Jul 12, 2007 7:48 pm
it just make some knocking sound lately when i rev up when the engine is hot so i just replace them to prevent more problems with the engine
Timoz
Postby Alex B » Thu Jul 12, 2007 8:00 pm
Well if its a big end you will need a crank grind anyway. In which case you may as well do the mains, in which case you may as well do the rings. So you may as well take the motor out and do a full rebuild :lol:
Postby Timoz » Thu Jul 12, 2007 8:12 pm
i dun have the money to do a full rebuild as it would cost thousands of dollars so i just wanna fix it temperoily until i got the money to rebuild it
Timoz
Postby Ae92typeX » Thu Jul 12, 2007 8:39 pm
Have you had a mechanic confirm its probably the big ends? by your description it may be...but there are other possibilities.
just my opinion, but if you cant afford to do all the bits that may possibly need doing, just make sure the oils ok and drive. If you replace the shels, but the crank is damaged they wont last long.
A torque wrench is cheap enough to buy (cheaper than paying someone)if you do do yourself and you will need one.
Ae92typeX
Postby Timoz » Thu Jul 12, 2007 9:38 pm
how do you know if the crank id damage? scratches
Timoz
Postby Ae92typeX » Thu Jul 12, 2007 9:55 pm
not the most super link, but have a read here:
http://www.babcox.com/editorial/us/us90126.htm
Ae92typeX
Postby Timoz » Thu Jul 12, 2007 10:32 pm
when i take the oil pan out do i have to replace the gasket?
Timoz
Postby Zak » Thu Jul 12, 2007 10:34 pm
Nope, they don't use one, they use a silicon sealer instead.
Zak
Postby Ae92typeX » Fri Jul 13, 2007 10:14 am
No offence intended, but if you are going to do yourself it would pay to get someone who has dome something similar before to assist.
Its a great learning opp, but done wrong could cause major issues.
Ae92typeX
Postby Timoz » Fri Jul 13, 2007 7:09 pm
i went to repco today and ask for a set of bearings but they said it comes in different sizes 40mm and 42mm so which one should i get for a blacktop 20 valve?
Timoz
Postby ChaosAD » Fri Jul 13, 2007 7:39 pm
bluetop is 40mm all other 4age are 42mm. But they should know that :?
ChaosAD
Postby Timoz » Fri Jul 13, 2007 8:05 pm
will i be able to use the ACL Race bearings, as i will just replace the old ones and it is one size fits all bearings or does it have a specific sizes and how much approximately they cost for a set of 4?
Timoz
Users browsing this forum: No registered users and 34 guests
