Or whether it's at all possible to get one from overseas without costing an arm and a leg ?
I want to get one fitted to my car, but they seem to be ghost items, unless you're buddy buddy with someone in Japan
toy8 wrote:exactly what are you after ? have you got any pics ?
Ard Righ wrote:Quick question, has anyone replaced a dash in a tezza before ?
I'm curious on the process of putting an upgraded dash, like TRD etc. If I got one 2nd hand, would it make any different how many Kms the dash had done in the previous car ? Or would it just come set to 0Kms ?
I'm not sure how the dash stores the odo reading, whether replacing it would cause much work in the swapover
Distrb wrote:I replaced my factory one with TRD one..
The ODO value is stored in the dash unit, so for example if i had 131,XXXkms on the factory dash, that value would stay with the factory dash.
If you buy a new aftermarket dash, the ODO would start at zero. or if you buy second hand, like i did, you'd have whatever kms the dash has on it... (in my case it was about 28.000kms)
Can cause a hassle at wof time, but just take down readings of what your original odo had, and where your replacement one started, and work out what your kms should be and tell your wof inspector.
Easy to install, just undo 3 screws and it pops out...
