****4agte starlet brake upgrade****
Postby corolla gt » Sun Jul 15, 2007 5:39 pm
hi i have been told that when u got for a cert for a 4age turbo in non turbo cars u have 2 do brake upgrades?
i have a kp60 and am putting a 4agze turbo in it will i have to do a brake upgrade if so what will b the best fit for price and stuff
its allready 4age now and didnt need to get a brake upgrade
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby Burning Angel » Sun Jul 15, 2007 6:49 pm
you just have to be able to stop 3 times in quick succesion from 100kmph with out getting brake fade. lvvta document here http://www.lvvta.org.nz/Brakes210502.pdf you can do an upgrade using u13 bluebird disks and sw20 calipers. http://au.geocities.com/quibel_nz/Evo3_02.htm. probably the easiest option.
I put carina/cressida struts+hubs+control arms in mine but its alot of messing around and your wheels wont fit under ur gaurds anymore.
Burning Angel
Postby fangsport » Sun Jul 15, 2007 7:13 pm
good to see the caliper mounted upside down in the last picture. must be a real mongrel to bleed properly!!
fangsport
Postby Adoom » Sun Jul 15, 2007 7:40 pm
fangsport wrote:good to see the caliper mounted upside down in the last picture. must be a real mongrel to bleed properly!!
Haha true. I had a clutch slave cylinder with the nipple on the bottom. I couldnt bleed it. I had to get a different one with the nipple on the top.
Adoom
Postby Burning Angel » Sun Jul 15, 2007 7:42 pm
ha good point. they say right front on them but im guessing they mount on the back of the hub on an sw20??? in that case i spose you could put it on the left hand side to get the bleed facing up?
Burning Angel
Postby fangsport » Sun Jul 15, 2007 8:04 pm
should work. maybe need to use a banjo fitting at the caliper or there will be a nasty bend ind the flexible line.
fangsport
