4AGE fuel economy
Postby fuzzilogyc » Mon Jul 16, 2007 5:45 pm
i wished it was that, but the mileage i'm getting IS driving like a granny... well almost. if i drive more "spiritedly", i get like 160km to 23 litres. thats like 7km/litre - seriously uncool for an NA 1.6 litre.
fuzzilogyc
Postby neo » Mon Jul 16, 2007 8:01 pm
It the oxy sensor plugged in and working?
Cant be an airleak on a silvertop as that would make it go lean, not rich.
neo
Postby fuzzilogyc » Mon Jul 16, 2007 8:06 pm
its not a silvertop, its a redtop small port.
and yes, oxygen sensor is plugged in, but is probably broken.
got fault codes 24 and 21 codes....
i think the blue plug that goes into the stock air box needs to be plugged in to make the intake air temp fault code go away... but i'm not sure, trying to establish what its for... here is the sensor i'm talking about
http://fuzzilogyc.bravehost.com/1.jpg[/url]
fuzzilogyc
Postby Calvin » Mon Jul 16, 2007 10:57 pm
fuzzilogyc wrote:here is the sensor i'm talking about
Calvin
Postby fuzzilogyc » Mon Jul 16, 2007 10:59 pm
Oh FFS, i'll try fix that soon...
fuzzilogyc
problems
Postby docTRD » Mon Jul 16, 2007 11:09 pm
just regarding the air intake temp sensor. the sensor itself is about 6-7cm long and tapers to a sort of point at one end, i think 2 wired goin into it. you definately need that plugged in. whereas the larger blue plug i still dont knw that that does but in my smallport corolla its always been just sitting upon other wires and i talked to a autoelectrician when i just had my engine tuned up recently and he said dont worry about it so meh and it doesnt seem to change anythin if i had it inline with the airflow or not inline so yea. but yea oxy sensor is first thing to check.
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby fuzzilogyc » Tue Jul 17, 2007 12:01 am
ok, i can't be bothered fixing that image thing.
docTRD seems to know about the plug i'm talking about but yeah, i'm still getting the air intake temp error code even after changing the sensor. i didn't run it for very long after changing it before checking the error codes the 2nd time around, so i'll check again tomorrow or something...
fuzzilogyc
Postby Zak » Tue Jul 17, 2007 9:25 am
Pull your efi fuse out for 30 seconds then put it back in, it will delete all the stored codes, then try again after going for a spin round the block.
Zak
Postby fuzzilogyc » Tue Jul 17, 2007 11:07 am
ah tru tru... gonna try that one. cheers zak
fuzzilogyc
Postby fuzzilogyc » Fri Jul 20, 2007 12:55 am
pulled the EFI fuse as suggested, and still gives me 2 errors... i think i'll be needing to change the oxy sensor soon...
anyone know of anyone selling one? a brand new one is bloody $175...
fuzzilogyc
