Aristo 94 , 2jz gte.. help me clarify if this engine is gud?
Postby strx7 » Sun Jul 22, 2007 6:39 pm
Mr Revhead wrote:its a V6 VR-4
RUN
amen, either that or buy shares in mitsi so you can get parts DIRT cheap
Postby gepsk8 » Sun Jul 22, 2007 7:18 pm
also get them remove sump and cam cover and remove all gunky oil, check if it got good size trans cooler? or if it got 1? fit 1 if it doesn't! , trans service a must will engine oil like that, i would change all my fluids personally.
gepsk8
Postby jdm 102 » Mon Jul 23, 2007 3:42 am
I am 100% that when we started it up ok , like the idle was fine.. not like it was struggling or anything it was just as a healthy engine would do, but we didn't let it warm up.. I know I switched it off to check some other things then mates started up and jus revved it.
However my main question is, if there does happen to be gunk, should I do an oil flush on it? because I was cautioned it would lead to doing the cam and certain other seals as the gunk dislodged.
I can't imagine that this would be too big an issue that it can't be fixed or something? :?:
jdm 102
Postby gepsk8 » Mon Jul 23, 2007 6:29 pm
if it never been serviced i would remove sump and cam cover and remove all gunky oil, it will cause problem later in life, especial imports as they do a lot of running time while in traffic. flush will help if it got high k's oils built up over 100,000 of k's or ur little late on service 15,000 instead of 10,000.
gepsk8
Postby jdm 102 » Wed Jul 25, 2007 2:42 am
read 170psi in each cylinder and as the mechanic said, drove very well.
its gone for compliance,
I have to admit my hopes were pinned on that Galant, but I just needed to hear from fellas like yourselves (who have had experience with em) to know that it wasn't as good as it seemed.. no doubt the drive was good and it was quick between the gears, but that woulda been no good if it broke on me and then later I had jus a heap of metal crap lying aroudn that no one in Brisbane would wanna fix or at any decent rate atleast :P
Bring on the Aristo :D
jdm 102
