catch can setup?
Postby Mr Revhead » Wed Jul 26, 2006 5:48 pm
your welcome
just so you know how important it is....
any air entering there will not be read by any sensors, or be controlled by the throttle........
Postby Dirtbag » Wed Jul 26, 2006 5:52 pm
Yea, I had the feeling I needed to fill the whole, but no one had made any real mention of, so best to check!
Yea, i once took the plenum off to have a gander etc and decided the car would run with the plenum off, I was so thick that day, DUH AFM!! That was one big leak that wasnt being picked up by the sensor :P
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby HZRDIZ » Fri Jul 20, 2007 1:35 pm
So stupid question but for catch can setup i will need something like this instead of running a line back into my intake?
http://www.trademe.co.nz/Trade-Me-Motor ... 796024.htm
Drinking 42 BELOW Passionfruit Vodka is like walking along the street and seeing this really hot girl and all you can think is "Man, I don't understand how anyone can be gay".
HZRDIZ
Postby TWSTD » Fri Jul 20, 2007 1:47 pm
Not if you are wanting to retain your PCV valve (which i would recommend). You would need a sealed can with 1 inlet and 1 outlet and no filter. Like this:
http://www.drivenperformance.co.nz/scri ... oduct=1009
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby HZRDIZ » Fri Jul 20, 2007 4:45 pm
Sooooo if we really wanted, like in TWSTD previosu picture we can just attach a breather to the outlet on the side and everything will be fine or is that not advisable???
HZRDIZ
Postby TWSTD » Fri Jul 20, 2007 5:24 pm
Side of what? Side of the catch can or side of the head? If the latter, then although its ok, you wont be alowed on a track with it like that as there is the potential for oil to blow out at that location...
Click here!
TWSTD
Postby HZRDIZ » Fri Jul 20, 2007 5:36 pm
TWSTD wrote:Side of what? Side of the catch can or side of the head? If the latter, then although its ok, you wont be alowed on a track with it like that as there is the potential for oil to blow out at that location...
Ahhh i see, hence why you have the catch can... gotcha... thanks
HZRDIZ
Postby groupagt4 » Sat Jul 21, 2007 11:08 pm
just a side question i wanna buy a oil catch can for my rally charade,wil a 1ltre 1 d? at the moment its just a rangi oil bottle with holes in it :lol:
groupagt4
Postby groupagt4 » Sun Jul 22, 2007 2:17 pm
ne1? :lol:
groupagt4
Postby TWSTD » Mon Jul 23, 2007 1:00 pm
I suggest you check the regs for the classs you are racing in - they may have specifications you need to follow. Personally I run a 700ml one in my charade.
Click here!
TWSTD
Postby Distrb » Mon Jul 23, 2007 1:17 pm
Taken From Schedule A Appendix 2 -
5.1 (7) Oil catch tanks: shall be fitted to
engines with open circuit crankcase breathing
systems as follows;
(a) Engines up to and including 2000cc
shall have a minimum of 1 litre catch tank
capacity.
(b) Engines exceeding 2000cc shall have a
minimum of 2 litre catch tank capacity.
Distrb
Regular Poster
Postby neo » Mon Jul 23, 2007 1:50 pm
at the same time, take of the plenium and clean out all the oil that will be sitting there, I was amazed with I pulled all my bits apart to clean them.
neo
Postby matt dunn » Mon Jul 23, 2007 9:17 pm
Distrb wrote:Taken From Schedule A Appendix 2 -
systems as follows;
capacity.
You also need to add there that the CC ratings are after multiplying with an equivilance factor for turbo's and rotary's.
Postby Caribeena » Mon Jul 23, 2007 9:36 pm
Sorry to steal the subject, but would this be correct? Pretty rangi for now, but engine isnt staying in there for too much longer...
Caribeena
Postby groupagt4 » Mon Jul 23, 2007 10:56 pm
systems as follows;
capacity.
thanx for that almost bought a smaller one today :lol:
my cars only a little 1l charade so should do.
just another question,my rangi oil catch can only has one inlet,how would i hook it up to a occ with two
groupagt4
Postby neo » Tue Jul 24, 2007 1:09 am
go get a T or Y piece / joiner (go classy and get a brass one), a local machine shop / nuts and botls supplier will have them.
As a temporary measure you could always use a plastic Y piece from the gardening dept at mitre 10 ...
neo
Postby Distrb » Tue Jul 24, 2007 9:13 am
Possibly, depends which way you read it... but thats a whole other can of worms...
Distrb
Regular Poster
Postby HZRDIZ » Mon Jul 30, 2007 4:48 pm
Simple and quick question (since im not near my car)
What is the inlet size of the breather on the side of a crank case (the one that runs to the standard filter box)on the AE111 Black top?
HZRDIZ
Postby Santa'sBoostinSleigh » Mon Jul 30, 2007 10:28 pm
HZRDIZ wrote:Simple and quick question (since im not near my car)
10 or 12mm from memory, dont quote me
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby matt dunn » Tue Jul 31, 2007 1:36 am
Quote Santa'sBoostinSleigh wrote: dont quote me
Whoops, sorry.
