Redd wrote:I've just got my car on the road and there are a few problems I wanna sort out before I retire from working on cars for a few months.
1. No highbeams just lows havnt checked bulds but i dont think its them they worked once then tried again and just darkness
2.No powersteering It has fluid and I can hear the pump whining but nothing
3. Passengers side window went down but now wont go back up I replaced the winder motor today from my other car and still nothing
4. Orange battery light on the dash
5. I put on a trademe sequencial blow off valve and it opens at idle I've tightened up the bolt on the back but just as bad
Any help with any of these would be a great help
Does it idle if you put your hand over the bov? I.e. is there any chance air is getting drawn in through the bov when the manifold is at vacum?Redd wrote:Yeah I would put on a factory bov if I could but the flange for the bov has been welded to the factory outlet pipe in place of the old one. Gunna try a mate bov to see if it is the problem.
Excellent point!avinesh wrote:do u have a aftermarket steering wheel some people remove the electronic board in between the steering wheel base to fit the boss kit that would have you having no power steering......
Zak wrote:But the SW20 power steering is electrical, I imagine there is a switch at the top to turn the pump on?
solitaire wrote:When i didnt have the sensor on the steering wheel plugged in it was really really hard to turn the steering wheel... the instant i plugged it back in it was easy to turn... felt exactly like the power steering was not working
Woopsfivebob wrote:solitaire wrote:When i didnt have the sensor on the steering wheel plugged in it was really really hard to turn the steering wheel... the instant i plugged it back in it was easy to turn... felt exactly like the power steering was not working
What sensor on the steering wheel?
