850 injectors too big for application?
Postby gasman » Wed Jul 25, 2007 8:16 pm
i found these:
big boys
and im wanting to use them on my 8.9:1 4agze bottom end with blacktop head turbo engine.
aiming for around 200+kw atw
for the price they are cheap as our dollar is quite high right now and roughly equates to 450 shipped. smaller flowing injectors seem to be even more expensive such as:
these
my concern is that they will be too big and the car wont idle well or at all,
"What can possibly go wrong?"
gasman
Postby IH8TEC » Wed Jul 25, 2007 9:13 pm
whether it will idle will depend on the computer and how well it's tuned. look at it like this, i'm running 550cc injectors and want 250kw atw. bazda runs 800cc injectors and has 330kw atw with room to play
Postby gasman » Wed Jul 25, 2007 9:28 pm
my reasoning behind the bad idle is that since the injector is so large that even the smallest pw from the ecu to injector will flow too much fuel and that fuel wont be as fine a mist as it could be since fuel press will be low at idle.
what duty cycle are you at now with the 550's? much room left to play with?
gasman
Postby IH8TEC » Wed Jul 25, 2007 9:47 pm
dont know, it's being tuned on saturday. i'm runnng base pressure of 50psi though, so the flow will be around 600ish. in theory there should be plenty of fuel for what i'm wanting
Postby rage » Wed Jul 25, 2007 10:06 pm
depends on your fuelling control and also the quality of the injectors
some people can idle fine on large inj
rage
Postby Bazda » Wed Jul 25, 2007 10:45 pm
what ecu are u going to run, and if you only want 200kw you only need 500cc injectors.
get those 650cc, that will be HEAPS
pm me and I can get them cheaper than that ebay one u found
Postby gasman » Wed Jul 25, 2007 11:14 pm
i was planning to run a link plus g2 but after talking to a guy from nzefi a lem g3 will be sufficient. the link seems to be able to do quite a bit for its price i reckon anyways.
that guy on ebay also has these:
set 1
set 2
gasman
