Steelo wrote:How much work is wiring the fuel pumps up?
postfach wrote:Steelo wrote:How much work is wiring the fuel pumps up?
Wiring pumps up is pretty easy, I just wire the pump directly to the battery (fused, of course) and have a relay off IGN to turn it on when the key is on
Bazda wrote:postfach wrote:Steelo wrote:How much work is wiring the fuel pumps up?
you should have it switched via ecu for safety.
matt dunn wrote:Postfach,
What car did you have that had an FP ECU in the boot?
panda_dan wrote:Mate i'v just done this setup in my ae85. So you can come look at mine if you want, i'm in hillsborough.
I have attached a simple bird's eye view picture of what i did. It's not a perfect system by any means but it gets the job done at a good price.
I am using my std ae85 fuel tank (which has 2 basic baffles in it FYI) with a surge tank and 2x fuel pumps.
Simple, cost effective set up.
I went to BNT and got some 3/8ths bundy ($90) and a pipe bender ($25 or borrow mine) and bent up a new feed line along the underside of my chassis. Which you must do unless you can find an original ae86 feed line - and some rocking horse sh*t while you're at it.
The original 3au feed was designed for 3 to 4 psi. You're now needing about 40psi. so your original feed is only handy as the new engine fuel return.
Then buy a surge tank. ($80 trademe)
Put a blacktop in tank pump ($20 pick a part) into your fuel tank and hook it up as the lift pump to go from your fuel tank to your surge tank.
And an overflow return from surge to fuel tank, and use your original 3au feed as the new return from your engine to your fuel tank. (Not back to your surge tank, as the fuel will be warm and you dont want that heading back to your engine)
Now that your surge tank will be getting fuel lifted to it by the blacktop pump, hook a 2nd hand Vl pump ($80 off trademe) between your surge tank and your engine supply bundy.
I bent it up to poke thru the floor near my surge tank.
Only other thing you'll need is 50cm ish of high psi rubber tube to use as fittings between surge / fuel tank / vl pumps etc ($30 repco) and about 15 small jubilee clips ($30 repco)
And that VL pump will flow thru an inline fuel filter ($20 repco) to the fuel rail
Pretty cheap and i'm hoping reliable
Danny
panda_dan wrote:Steelo: Yep that's the guy made my surge tank I think.
Just get one with one 12mm outlet on the bottom for your feed, and 3 10mm outlets on the top. Those trademe guys should make to your requirements no extra cost if you ask nicely.
doin_donuts: I'll be in touch over the weekend if I get some time to work on the car on sunday prob most likely.
Danny
