Another Hiccup
Another Hiccup
Postby TRD_ZERO » Sun Jul 29, 2007 4:52 pm
OK i went for a warrent yesterday and the guy didnt want to pass me as i got camber plates at the top of the front struts. Fair Enough as they didnt have any markings indicating what brand they were( I dont think TRD make camber plates anyway) I have to get a cert for them. I was also thinking this is only for street use couldnt i try something else and maybe replace them with a factory looking top hat? They are trd adjustables. How much would they cost? Is it possible? What would be the work involved doing this. If its all too much time and money ill just get a cert. I just dont want to cert it just yet as im planning to cert it at a later stage due to other mods. So anybody got any ideas?
TRD_ZERO
Postby rollaholic » Sun Jul 29, 2007 7:13 pm
doubt you'll get custom tophats made for much less than the cost of a cert...
Postby AceSniper » Sun Jul 29, 2007 7:59 pm
put stock stuff in untill your ready for cert
AceSniper
Postby Mr Revhead » Sun Jul 29, 2007 10:15 pm
as above, TRD shocks fit stock units
and TRD dont do camber top hats so they will be something else
Postby TRD_ZERO » Thu Aug 02, 2007 5:53 pm
OK yeah as Acesniper said put the stock stuff back in until cert.............Just a question here, so its only the camber top hat plates that are holding me back would there be any issues with just putting the factory front struts back in and leaving the adjustables in the the rear for the warrent or is that a no go?? Would that pass a warrent? Or would i have to change them all round?
Did you guys mean fit the stock struts or just fir the stock tophats?
IS this what im after? which one or both?
http://i22.photobucket.com/albums/b346/ ... 0_2870.jpg
http://i22.photobucket.com/albums/b346/ ... 0_2869.jpg
TRD_ZERO
Postby rwd_mayhem » Thu Aug 02, 2007 7:21 pm
1st pic is what the original spring seats into, the 2nd pic is the top hat, which is what you will need to change for wof.
current: 1975 Valiant Regel
rwd_mayhem
Postby TRD_ZERO » Thu Aug 02, 2007 7:39 pm
Oh ok so i just need those those triangular shape ones? Fitting them? Would i have to take them to a suspension shop to get it put on?
TRD_ZERO
Postby rwd_mayhem » Thu Aug 02, 2007 8:34 pm
yea the triangular ones, nah its a pretty simple job, just need some spring compressors.
rwd_mayhem
Postby TRD_ZERO » Thu Aug 02, 2007 9:54 pm
Yeah thats the thing i dont have any spring compressors, as i didnt really think id ever use one.
TRD_ZERO
Postby BigDon » Fri Aug 03, 2007 1:57 pm
Are they coilovers? you say TRD adjustables so not clear, if they are coilovers just take the struts out mark where the spring perches are wound up to and then get a c-spanner and wind the perches down to take the load off the spring then you can change the top hats and reverse the process.
Make sure you clean the threads before winding them down. I have taped up lower threads on mine so they don’t get dirty.
If you take the struts out you will need to get wheel alignment. So if your getting it certed in the next six months swap the top hats back straight after the warrant and then go get an alignment asap.
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby postfach » Fri Aug 03, 2007 3:12 pm
you could do that, or you could borrow my spring compressors, and you won't have to mess around with trying to put the perches back where they were.
postfach
Postby TRD_ZERO » Fri Aug 03, 2007 4:19 pm
Label me ignorant but im not sure of the difference between coilovers and adjustables hence the reason i call them adjustabels I think its the TRD Sushkit, I think this is them:
They have the adjustable shocks at the top and are also blue in colour.
IM just trying to get ahold of those tophats first...........and waiting to get my car back from the panel beaters as i had a pretty nasty nose to tail this morning on the motorway......So yeah my car is pretty damn bad :roll:
TRD_ZERO
Postby postfach » Fri Aug 03, 2007 4:49 pm
People often mistakenly call adjustable coilovers "coilovers".
"Coilovers" is basically slang for "coil over shock(or damper, take your pick)", where the spring and the shock are one unit, as seen in probably 99% of modern cars, instead of a seperate shock and spring (I think you can see an example of this in the back of an AE86?)
Adjustable coilovers are just that, a combined spring and shock that have any or all of the following: damper, spring rate and ride height adjustment.
Adjustable suspension is also available in cars that don't have coilovers, I think in this form only the damper is adjustable, ride height and spring rate would most likely require replacement of the shock, spring or both.
Hopefully that clears things up for you, and if anything I've just written is incorrect, someone feel free to correct me.
Oh and that sucks about the accident dude, hopefully you have insurance and they pay out.
postfach
Postby rollaholic » Fri Aug 03, 2007 6:48 pm
postfach wrote: (I think you can see an example of this in the back of an AE86?)
you can indeed! several european manufacturers, notably BMW, still use this setup today.
Postby TRD_ZERO » Fri Aug 03, 2007 8:09 pm
Yeah that makes sense now lets just hope i can remember it. Oh and about the accident yeah i took the whole day off work to sort shiz out as the guy who hit me did not have insurance, so thats just beautiful and ive only got 3rd party.
TRD_ZERO
