are the rear and front crank seals on all 4ages the same?
also are waterpumps interchangable across all 5 generations
bluemaumau wrote:are the rear and front crank seals on all 4ages the same?
matt dunn wrote:bluemaumau wrote:are the rear and front crank seals on all 4ages the same?
1, possibly, except maybe the early bluetop as the craks are different,
2, definatly not, RWD water pump is different to FWD and ST and BT are another 2 differerent one's, so at least 4 versions.
matt dunn wrote:So i'd say use the water pump to suit the head.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
