Windom stuttering/surging ?
Postby gmacrae » Sun Aug 05, 2007 7:46 pm
Hey guys, i just picked up a windom and it has a hesitation sometimes when pulling away from a stop. The engine surges 3 times and then picks back up and runs sweet. it only does it about 20% of the time. I just did a big service and replaced the plugs, made no difference, ecu has been reset. Will be flushing the coolant soon, could be a bubble in there i guess? Will also replace the fuel filter this week
Any ideas? Would be good to get it sorted seeing as its probably a minor - Cheers for any help
Gene
gmacrae
Postby matt dunn » Sun Aug 05, 2007 9:04 pm
they break the air pipe between the AFM an the throttle,
check in between the ribs in the flexi part for breaks.
had had that symptom described by lot os people an lots of things from surging to missing to broken engine mounts.
also, if it is broken check your engine mounts as they are just as common to break too.
Postby gmacrae » Sun Aug 05, 2007 11:56 pm
matt dunn wrote:they break the air pipe between the AFM an the throttle,
you da man Mr Dunn :) - ill check it out tomorrow.
gmacrae
Postby gmacrae » Mon Aug 06, 2007 5:39 pm
Yup, cracked intake pipe, cant believe i didnt spot it
gmacrae
Postby rollaholic » Tue Aug 07, 2007 12:14 am
the intake pipes usually break because an engine mount is rooted, engine flexes too much as a result till the pipe splits.
so check your engine mounts too!
Users browsing this forum: Bing [Bot] and 16 guests
