turbo 20v
turbo 20v
Postby matt9ball » Sun Jul 22, 2007 8:52 pm
im woundering if the TURBO LINK which runs with standard ecu...will run the turbo conversion im trying to do???i dont want i seriously boosted 4age at this stage just a mild turbo 4age...
what are the other/cheapest options??ecu wise....
im just trying to lower the cost anyway with the ecu side of things..
I also see link lems on trademe for like 800 odd??is this ok....but dyno tunning you looking at another 500 right?
Engine is 4age 20v silvertop....
Thanks
matt9ball
Postby AceSniper » Sun Jul 22, 2007 9:25 pm
a decent tune with a good ecu is what will make your engine last or blow up in your face.....
Save your $ you will find a lem or g3 for 1300? or less
AceSniper
hi
Postby JP0976 » Sat Aug 04, 2007 9:03 pm
Cheap and turbo conversion dont go in the same sentance if you want it to last longer then a week or actually go faster then your standard motor.
JP0976
Postby lorolla24 » Sat Aug 04, 2007 9:48 pm
I'd agree with that, Turboing and cheap don't go together.
Spend your money on a ECU like a G3 or even a V5 if you can find one, it will give best results and the ability to change with different set ups.
You could even use it to run the std engine and see what you get.
My Link V5 doe's awsome job on my silvertop turbo, I built the engine on the cheap (No labour cost's and find the bargins of Trademe) and it still cost me between $10-$12 grand.
You will spend $500 easy on tuning.
lorolla24
Re: hi
Postby tsoob » Tue Aug 07, 2007 12:16 am
JP0976 wrote:Cheap and turbo conversion dont go in the same sentance if you want it to last longer then a week or actually go faster then your standard motor.
Yeah, i was in the garage with a mate the other day working out the rules of buidling a gte,
number 1 is open your wallet
number 2 is learn how to use swear words is muiltiple combinations
number 3 is dont expect to do it in 6 weeks
tsoob
Postby IH8TEC » Tue Aug 07, 2007 12:22 am
rule number 4, more swear words :lol:
Postby tsoob » Tue Aug 07, 2007 9:48 pm
rule number 5 open your wallet again!!
tsoob
