ign timing non toyota
Postby bluemaumau » Wed Aug 08, 2007 6:47 pm
tommorow im tunning up the rellies cars, and was just wondering if all cars are set to 10BTDC?
and do most cars need the diagnostics to be bridged?
cars in questions are 92' nissan largo van (CA20)
and a 97' suzuki cultus crescent (G15A)
Postby Lloyd » Wed Aug 08, 2007 6:52 pm
CA20 will probably want closer to 5 off the top of my head. As for the Suzuki I couldn't say for sure, will be electronic at a guess so will probably run 15ish base. Cant imagine you'd need to adjust things like that too often on a 97
Postby strx7 » Wed Aug 08, 2007 7:29 pm
The G15A should be at 5-6 degrees at idle when warm, in saying that my one runs at 12 degrees at idle and seems fine (no knock)
The only thing engine related wise that plays up on the G15A's are the Map sensor.
If you need any parts PM Me.
Postby rollaholic » Wed Aug 08, 2007 11:51 pm
i'd be surprised if the G15A was even adjustable?
Postby bluemaumau » Thu Aug 09, 2007 9:59 am
sweet as cheers guys
