l1ttle_d3vil wrote:?
and you can't use a genuine ae86 bellhousing with a 20 spline t50. ae86s came with 22 spline boxes so if you want to run a 20 spline on an ae86 you need a spacer made up otherwise your gearbox will need a rebuild after about 5000km![]()
im pretty sure thats how it is, anyone correct me if i'm wrong
l1ttle_d3vil wrote:it isn't so much to "centralise" it, but to stop the input shaft moving backwards and forwards between the bellhousing and gearbox, literally. i've got pics of the difference, as you can see the 20 spline bearing sits right "inside" the seat, due to the bearing being smaller than the 22 spline. this in turn makes the bearing sit further down, or "inside" the bellhousing.
QikStarlie wrote:does anyone know if 5th gear and related parts from a t50, will fit in a t40?
Users browsing this forum: No registered users and 33 guests
