vvtirep wrote:so i just used a whole bottle(4L) over 5000kms.
vvtirep wrote:s there ment to be a bronze washer on the sumpill have 2 chack tht cos i dunt remember seeing one wen i changed oil last time. will have to look 2morrow.
it dosnt seem to be leaking on to mi driveway at all.
vvtirep wrote:yea i no. its crazy... is there ment to be a bronze washer on the sumpill have 2 chack tht cos i dunt remember seeing one wen i changed oil last time. will have to look 2morrow.
i did have a problem with my oil pressure sender so i removed it and got a bolt to put into the block.
its very odd
Best you start saving and looking for a second motor now for when your retardedness destroys the one you have now.
vvtirep wrote:i did have a problem with my oil pressure sender so i removed it and got a bolt to put into the block.
AceSniper wrote:wouldnt use magnatec mine eats it with-in a week or two and engines in good shape...
if you can find it.... the below oil has run very well in mine under hard driving and not vanished like the magnatec
http://www.valvoline.co.nz/prod01211111.htm
Users browsing this forum: Bing [Bot] and 23 guests
