Rose joint suspension
Postby ke25sr » Mon Aug 27, 2007 7:05 pm
Ive decided im going to get some rose joints and fit them onto some lower arms.
all im going to do to start with is the lower arm ill look a sway bar links and caster arms after i do this.
I'm just wanting to no if any of you guys have any pointers for me before i star cutting shit up.
ke25sr
Postby postfach » Mon Aug 27, 2007 7:35 pm
I've had this done on the back of my car, have a look at my project thread for some pics. If you need any specific photos PM me and I'll sort some out for you.
postfach
Postby Mr Revhead » Mon Aug 27, 2007 7:51 pm
talk to your cert guy before you start.
Postby 2LTR Rona » Mon Aug 27, 2007 8:15 pm
Good advice from Rev, no point in cutting shit up & then finding out you will be failed on it.
On a side note is this for one of the KE Corolla's ? If so my KE has pretty much had all of that done to it....could take a few pics as the front struts are currently off it.
heading out this weekend to work on it
2002 Altezza, 1974 KE25
2LTR Rona
Postby ke25sr » Mon Aug 27, 2007 8:27 pm
2LTR Rona wrote:Good advice from Rev, no point in cutting sh*t up & then finding out you will be failed on it.
pics be awesome man.
as for cert ill find a way around it.
ke25sr
Postby ee904age » Mon Aug 27, 2007 9:00 pm
Famous last words.....If it were changing a seat or steering wheel fair enough but cutting up suspension arms etc is utter stupidity.
Too bad for everyone else on the road
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby 2LTR Rona » Mon Aug 27, 2007 9:20 pm
Not if it is done properly & under the advice of a certifier. Not everyone cuts corners when it comes to modifications :roll:
2LTR Rona
Postby ke25sr » Mon Aug 27, 2007 9:21 pm
i think you misunderstood me. I do not plan on making my car unsafe.
as for cutting up suspension arms I have plenty spare so i reckon i can sacrifice a set
ke25sr
Postby postfach » Mon Aug 27, 2007 9:21 pm
A little harsh but somewhat true. Instead of modifying the existing arms a better option would be to get steel tube with an ID to match the rose joint threaded end, cut them to length and tap the inside of the tube, I know that's how mine were done.
Not sure on what type of steel you're supposed to use but IMO steer clear of moly, the guy that made mine said if you go down that road you need to get the arms xrayed to check for cracks and things basically every year, and it's not worth the extra cost and hassle for the small amount of weight you save.
postfach
Postby 2LTR Rona » Mon Aug 27, 2007 9:22 pm
will see what I can take this coming weekend and then post up for you
2LTR Rona
Postby ke25sr » Mon Aug 27, 2007 9:35 pm
I would appreciate pics.
I got lots of ideas.
Be good to see what has been done.
I reckon this looks a little weak.
http://users.bigpond.net.au/lachlan/car ... e25_24.jpg
ke25sr
Postby postfach » Mon Aug 27, 2007 10:29 pm
Here's a rough diagram of how mine are attached to the mounts on the subframe:
Going from the pic in your post, the mounts on your car are basically the same at that end, the other end of the arm depends on how it attaches to the hub/whatever
postfach
