guy's,
what can i do to improve my 7A ignition power? Other thn using MSD? Is there any tip tricks i can do so?
normality78 wrote:there is nothing wrong on it just that i wanted to have a bigger spark so to say better combustion
barryogen wrote:get a better battery?
strx7 wrote:barryogen wrote:get a better battery?
consider a battery has say 12.8 volts, and when a car is running the alternaor puts out somewhere between 13.8 and 14.9 volts, putting a larger battery in a car, doesn't achieve jack in regards to actually engine running voltage.
I'll admit firstly, that I'm no battery/alternator guru specialist. But how does this make sense? Once a battery is up to "full charge", it is just requiring a float amount of current to maintain it. Unless the battery has a very high internal resistance, I don't see how it will require more current.matt dunn wrote:but it will require more current into it to keep it charged and so the alternator will drag more HP.
