My trueno has the podfilter setup as shown below, inside the previous owner has placed a sensor thats quite long, red and with a pointed tip ( roughly =|==> kind of shape ), which I assumed is something to do with airflow.
Now this is where i've gotten confused, running off the top right are two little hoses, one goes to what i guess is the vacuum actuator (i may be completely wrong here?), the other doesn't go anywhere, but in stock configuration I think went to the airbox. However, now it goes no where, and my gf's dad not knowing what it was put a screw in it... I forgot about it and carried on. When the engine is idling with the screw removed, I notice the revs drop if I hold my finger over the end of this hose, and pick up again when I remove my finger. So i've taken the screw out. I test ran having the screw in, having the screw out and the hose jamed into the pod filter, and screw out with hose just sitting there, and arn't sure if I actually noticed a different or was just looking for a placebo effect.
Can anyone explain what's going on? At high revs I used to hear the engine note change which I assumed was TVIS, now I don't even know if I'm hearing it anymore.
