Rear AE86 strut brace question
Postby allsecretlove777 » Thu Sep 13, 2007 4:55 pm
I bought a AE86 rear strut bar for my AE85 but there are no holes to mount it :? Im just wondering do I have to drill it and mount it myself :?: Some pictures below descibe my situation :arrow:
:evil:
Thanks for your help
allsecretlove777
yep
Postby ezy10s » Thu Sep 13, 2007 5:11 pm
Well you could just get a hammer and a nail and bash it through!! :twisted:
But yeah drill the holes.
Member #244
Gone fishing until further notice
ezy10s
Postby Rick » Thu Sep 13, 2007 5:28 pm
Or you could weld the red plates onto the car.
Postby allsecretlove777 » Fri Sep 14, 2007 1:52 am
Ill be getting out the drill then, thanks for your ideas
allsecretlove777
Postby d1 mule » Fri Sep 14, 2007 1:01 pm
yeah just get it as centered as possibble, i had that exact one im my old 85 made a massive difference over stock, then a half cage made hardly any differencs over the strut brace, bloody good value for money mod :D
d1 mule
Postby Rick » Fri Sep 14, 2007 5:34 pm
Or for an even cheaper option I used a piece of rollcage bar and welded it in between the rear shock towers
Postby NZ_AE86 » Sat Sep 15, 2007 10:47 am
Rick wrote:Or for an even cheaper option I used a piece of rollcage bar and welded it in between the rear shock towers
Where will you be mounting your belts to? Or is the cage not finished?
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Rick » Sat Sep 15, 2007 10:54 am
NZ_AE86 wrote:Where will you be mounting your belts to? Or is the cage not finished?
Cage finished, belts will be mounted off the horizontal bar, just behind where the seats are going to be mounted.
Postby allsecretlove777 » Sun Sep 16, 2007 3:32 am
cant really complain for $80 new plus i guess it will save some welding work
allsecretlove777
Postby Mr Revhead » Sun Sep 16, 2007 11:45 am
sell it and recover your $$
it doesnt do anything.
Revhead claims ..
Postby Xylotrope » Sun Sep 16, 2007 1:23 pm
So are you saying that rear strut bracing does nothing or that particular one does nothing .. what about the red car with the welded pipe between the rear struts .. is that effective ? ..
More information please ..
Thanks
"Theology is the effort to explain the unknowable in terms of the not worth knowing"
"If GOD lived on earth people would break his windows"
Xylotrope
Xylotrope
Postby d1 mule » Sun Sep 16, 2007 1:35 pm
trust me it made a MASSIVE difference in my 85. the front made bugger all difference and the HALF CAGE made only a slight improovement over the strut brace.
if it could be measured in % id say the rear strut brace was a 100% improovement over stock and the half cage was a 50% improovement over the strut brace, and for the price $80 for the strut brace V $800 for the cage its def a worthwhile mod
d1 mule
Postby Mr Revhead » Sun Sep 16, 2007 2:36 pm
how can it do anything?
its not bracing anything that can move the suspension...
AE86s have a live rear axle with a 4 link and panhard rod.
the suspension mounts are under the floor forward of the shocks.
any deflection of the shock mounts is minimal at most (ever seen an ae86 crack there?) forces going up are spread amoungst the shocks and springs which mount at different points, therefore spreading the loads much more widely. if they did need strengthning there, a bar between them wouldnt work that well, some brackets or double skinning would work better.
of more importance would be the arm bushes and mounting points.
in a car with say a macpherson strut where the camber etc could be altered by deflection of the strut tower a strut brace will make a difference. but in a live axle car, movement there (if any) wont be felt by the driver.
as for claims it makes a MASSIVE difference, if it did then i would be having a hard look for some SERIOUS issue with that car.
in a rollcage situation it changes a little, as then apart form the safetly aspect, you are also (often) trying to stiffen the car as a whole, not in a specific area. in some designs a bar there can help with the overall stiffness. depending on where the other bars are.
but on its own, no a bar there doesnt do anything worth while.
have a good think about how forces are transmitted through bars and structures. ie not just the individual bar, but the structure the bar is part of.
Postby NZ_AE86 » Sun Sep 16, 2007 4:17 pm
Are you not worried about that bar moving in a side impact? I would want some bars off that bar. In a hard side impact that bar has nothing to stop it moving which will either tighten your belts or loosen them, either of which could cause a big problem.
On topic - Revhead is right as to the amount of difference that strut brace will/could make.
Current rides;
1986 Levin GT
NZ_AE86
Postby d1 mule » Sun Sep 16, 2007 9:22 pm
all i no is the car felt much stiffer after fitting the rear brace.
d1 mule
Postby Dell'Orto » Sun Sep 16, 2007 9:51 pm
Placebo effect?
Postby allsecretlove777 » Sun Sep 16, 2007 11:02 pm
The reverend makes a good point. However I would of thought adding a rear brace would help the light flexible chasiss become rigid? :? ill take d1 mules experience over others theories for the fact that i might get a massive improvement :D
allsecretlove777
