How Can I identify c52/c56 gearboxes?
Postby ChaosAD » Sat Sep 15, 2007 4:21 pm
I need a c52 or c56 gearbox that can have a starter mounted on the intake side. Have found a 92 levin with a silvertop fitted (car has drum brakes so must be a conversion).
How can I confirm the gearbox is a c52 or c56 and not the origional gearbox that was fitted to the old 4afe or whatever it had?
If it was still in the car I could see what revs it does at 100km in 5th, but its no longer in the car.
Any idea's? would the number stamped into it be of any use?
ChaosAD
Postby neo » Sun Sep 16, 2007 1:14 am
The only tell tail sign I know of is to look above where the passengers side cv enters the box.
A C52 'should' have a black piece of plastic as a shield. a C56 has a smaller shield but its part of the alloy g/b casting, and you cant attach the piece of plastic to a C56.
neo
Postby ChaosAD » Sun Sep 16, 2007 12:05 pm
how about the standard gearbox that comes with a 4afe? as they have different final drives. ie 100km/h in fifth is 2,500 as opposed to 3,500rpm
ChaosAD
Postby AceSniper » Sun Sep 16, 2007 5:40 pm
neo wrote:The only tell tail sign I know of is to look above where the passengers side cv enters the box.
the c52 and c56 found in a ae101 both have the black sheld on the cv.
A ae111 is cast the same and has places for the bolts to be taped for a sheld but no threed
so in short that dosnt help unless you have a AE111 c56 box infront of you
Alot of c series box's have greenish writing on them im not sure if that can tell you?
You can easly tell if its a ae111 box (but may not be able to tell Ge VS Fe ratios) AE101 they all look the same
Iv seen "c52's and "c50's on late 90's 4afe's im not sure if much internally differs but the crown and pinion is the main reason for lower rpm I belive
AceSniper
Postby ChaosAD » Sun Sep 16, 2007 7:46 pm
AceSniper wrote: AE101 they all look the same
So there is no way to visually distinguish if an ae101 box came from a 4age or 4afe?
ChaosAD
Postby AceSniper » Sun Sep 16, 2007 8:45 pm
if you have the shafts the 4age ones have the right shaft with the hanger bearing, apart from that I think you would need to turn the input and do the maths of the output to get an idea of ratio
Iv had all of these box's apart and from what iv seen there is no tell tail signs to id them :x
AceSniper
Postby ChaosAD » Sun Sep 16, 2007 9:37 pm
Hanger bearing? is that like a universal joint in the middle of the shaft so the car behaves like the shafts are of equal length?
ChaosAD
Postby AceSniper » Sun Sep 16, 2007 9:51 pm
yea along those lines... found on the ae101 an ae111's has 3bolts onto the block with a bearing that holds the shaft so then the cv is after that... rather than the FE setup that runs one shaft all the way over with the cv right up at the gearbox
AceSniper
Postby KinLoud » Sun Sep 16, 2007 10:47 pm
I usually work out the ratios to make sure what box it is. Only way to be really sure.
Ken
Ham
021 408 863
Postby ChaosAD » Sun Sep 16, 2007 10:54 pm
Thanks, ill find out if it had those shafts.
So I put it in 5th and see how many revolutions of the driveshaft it takes to turn the input shaft 10 times or something. I guess If I hold one shaft and turn the other id have to double it though.
I just multiply the gear ratio and final drive ratio together aye?
ChaosAD
Postby AceSniper » Mon Sep 17, 2007 2:36 pm
3rd and 4th gears will tell you if its a c56
c52
1st 3.166
2nd 1.904
3rd 1.31
4th .969
5th .815
c56
1st 3.166
2nd 1.904
3rd 1.392
4th 1.031
5th .815
and Ge final is 4.3
AceSniper
