AE101 ECU Location
AE101 ECU Location
Postby big-ben-007 » Sat Sep 15, 2007 1:57 pm
Hey, Just a quick question, on my 91' ae101 levin gtz, where abouts is my ecu located??????
The reason I need to know is that my speedo has gone a-miss, rapidly flicking between 20-40kph no matter how fast im going above about 10 kph. Behind the actual speedo seems fine and there are no wires loose on the g-box, so im trying to find the problem before I have to spend some $$ for and auto-sparky
cheers for any responses
Now: 1956 Dodge Pick-up, 1988 EP71 Starlet
Before: 1985 Ford Telstar, 1989 Mazda 323, 1991 Ford Telstar s/w, 1991 Nissan Pulsar GTI, 1991 R32 Nissan Skyline RB20DE, 1991 AE101 Levin GTZ Superstrut Version
"Oh man, I just shot Marvin in the face" - Vincent Vega
big-ben-007
Postby bluemaumau » Sat Sep 15, 2007 1:59 pm
between firewall and gearstick. under dash.
99% sure, is on a ae92 anyway
Postby Infinite » Sat Sep 15, 2007 2:43 pm
^-- what he said is gospel
Lots
Infinite
Postby big-ben-007 » Sat Sep 15, 2007 3:32 pm
Just done diagnostic check and gives an "ok" code.
I had and alarm installed just recently by ashley audio, could this be the problem, with faulty workmanship etc. ??
Also now my Rev gauge had decided it now doesnt like me as well, I apparantly idle at 0 rpm and going 110kph its saying Im reving at 2500 rpm which is off by about 1000rpm, this is a problem that has just happened today . However the fuel, temp and volt gauges are all working perfectly, as well as my aftermarket boost and exuast temp guages
Does anyone have any idea on what is going on here????
big-ben-007
Postby Infinite » Sat Sep 15, 2007 7:20 pm
i had that exact! same problem after installing an alarm..... turned out changing the power wires for the alarm fixed it...
Lots
Infinite
Postby neo » Sun Sep 16, 2007 1:17 am
Dude, just call the boys up, drop the car off and they'll sort it out.. Their good like that
neo
Postby big-ben-007 » Mon Sep 17, 2007 2:48 pm
Getting the alarm electrics checked out by ashley audio on thursday arvo, hopefully will all be sussed, thanks for all the feedback all :D
big-ben-007
Postby big-ben-007 » Sat Sep 22, 2007 3:26 pm
Fixed the problem to therev gauge myself :D , it was only off the resting place it has at 0 so my fault anyways :o .
The speed gauge still not fixed :? , aparantly not the alarm that causing it.
Rung up some guy from toyota(head of something) who says that could be down to wear and tear being 16 years old now and best bet is to fork out for a second hand one :roll:
Any thoughts?? :?: :?: :?: :?:
big-ben-007
Postby Infinite » Sat Sep 22, 2007 5:02 pm
pay to get it checked there could be a broken wire in the loom.....
Lots
Infinite
