Smallport Flywheel Size
Postby HachirokuGTV » Mon Sep 17, 2007 7:52 pm
Mine came with an 8 1/2 inch flywheel same size as 20v correct?
Is 8 1/2 inch normal for 16v smallport, non tvis, 7 rib etc, etc?
HachirokuGTV
Postby frost » Mon Sep 17, 2007 7:54 pm
yes thats normal, same size as 20v
Postby HachirokuGTV » Mon Sep 17, 2007 7:57 pm
Thanks Frost.
HachirokuGTV
Postby HachirokuGTV » Mon Sep 17, 2007 7:58 pm
So could I use a Blacktop flywheel? They are lighter right? Will an 8 1/2 flywheel still be ok with t50 gearbox?
HachirokuGTV
Postby Rick » Mon Sep 17, 2007 8:40 pm
HachirokuGTV wrote:So could I use a Blacktop flywheel? They are lighter right? Will an 8 1/2 flywheel still be ok with t50 gearbox?
yes, yes (sort of) and yes
Postby frost » Mon Sep 17, 2007 9:32 pm
as long as you buy the clutch cover to suit the flywheel tis a good upgrade,
Postby thegreatestben » Mon Sep 17, 2007 10:12 pm
Might as well get a new clutch.
I think warrick quoted one at $180 tgp.
thegreatestben
