Squeaking from the rear suspension : Toyota Camry
Postby no_8wire » Tue Sep 18, 2007 10:13 pm
I have checked and it is not small rodents of any description...
Basically when ever I hit a bump the rear suspension will squeak...I thought that it might be the shocks so I replaced both of them. I thought I had found the problem as one side was completely rooted (wouldnt even push back up 20min after pushing it down 8O )
The other side was sweet...
However the problem is still there.
Whats next?
Control arms bushes/swaybar bushes?
no_8wire
Postby Rick » Tue Sep 18, 2007 10:47 pm
I would say with out a doubt it will be the rear sway bar bushes
