problem solved re:Speaker sound gone?
Postby Omegah » Mon Sep 24, 2007 5:45 pm
i was driving around a few days ago with music playing, then all the speakers cut out, and just the sub was going. sometimes the music cuts in but cuts out straight away.
does anyone have any idea what could have caused this?
thanks
Omegah
Postby pjay » Mon Sep 24, 2007 5:49 pm
amped speakers?
pjay
Postby d1 mule » Mon Sep 24, 2007 6:00 pm
speaker wires touching bodywork. bad connection somewhere would be my guesses
d1 mule
Postby Omegah » Mon Sep 24, 2007 7:05 pm
speakers arent amped. i checked all the wires in the back of the headdeck and none of them have come loose
Omegah
Postby bbq1988 » Mon Sep 24, 2007 7:12 pm
blown amp in the headdeck?
Baked, Not Fried.
bbq1988
Postby d1 mule » Mon Sep 24, 2007 7:15 pm
im talkin where the wire plugs into the speaker, i had trouble with that earthing on the body of the car in my old SR
d1 mule
Postby Omegah » Mon Sep 24, 2007 7:22 pm
bbq1988 wrote:blown amp in the headdeck?
the fuse in the back of the headdeck isnt blown if thats how you tell the headeack amp is blown. the headdeck still works fine btw
d1 mule wrote:im talkin where the wire plugs into the speaker, i had trouble with that earthing on the body of the car in my old SR
ah ok so check all the wires where they connect to the speaker to see if any are touching the body?
Omegah
Postby Omegah » Mon Sep 24, 2007 7:42 pm
cheers d1 mule one of the back speakers came unpluged and the wire from the headdeck is touching the body :)
problem solved
Omegah
