2tgeu 2 kinds
2tgeu 2 kinds
Postby 79rolla » Wed Sep 26, 2007 11:25 pm
hey just found a thing on the net about the compresstion of my 2tgeu coz i need them for they ges that are helping me buld my engin know how much they can plane/need to do in the way of cam grind
there are 2 diferent ones and i need to know witch one iv got (one has 8.4:1 compresstion and the other 9:1) whats the easyest way to tell? they hav diferent cams and pistens
can anyone discribe the pistons accuritly or find a pic of atleast one??
thanks heaps
past: AE82 FXGT
79rolla
Postby Dell'Orto » Wed Sep 26, 2007 11:33 pm
CC the head and measure the deck height, then you'll know for sure.
Postby 79rolla » Wed Sep 26, 2007 11:48 pm
what heights should they be??? (the engin is in peces atm aswell and its how i got itt if it makes ANY diff)
past: AE82 FXGT
79rolla
Postby Dell'Orto » Thu Sep 27, 2007 6:37 pm
Dunno, but if you have flat pistons and they're level with the top of the block, then what ever the size of the combustion chamber is + h/g will determine your CR.
Postby 79rolla » Thu Sep 27, 2007 8:06 pm
well my pistens have a rased bit in the middle of them but im not sure if the lower compresstion ones are flat or rased witch it would be good if somone who knows could discribe them/post a pic of one
past: AE82 FXGT
79rolla
Postby ke25sr » Sat Oct 20, 2007 11:02 am
79rolla wrote:well my pistens have a rased bit in the middle of them but im not sure if the lower compresstion ones are flat or rased witch it would be good if somone who knows could discribe them/post a pic of one
is the dome on the piston offset? is the combustion chamber basic Hemi shape or is it more detailed.
The piston with a dome in the center is the older type ( i think higher compression) piston with offset dome ( i think is lower compression) i have it written down at hom ill check thisafternoon for you.
ke25sr
