sxymr2 wrote:i would say above the sump as it is in turbo cars
~SlideWays~ wrote:Well I think I'll try it with the can draining to below the sump oil level, that way there is no crank case pressure pushing oil back up the drain line, much like what matt described.
barryogen wrote:~SlideWays~ wrote:Well I think I'll try it with the can draining to below the sump oil level, that way there is no crank case pressure pushing oil back up the drain line, much like what matt described.
Correct me if I'm wrong, but if the crank case is under pressure, the oil thats in it will be too.
So putting the drain below the oil line will mean that rather than vapor being pushed up the return line, you will have oil pushed up there instead.
right?
True-No-Turbo wrote:how about just using a ball valve on the drain back from the can?, then it wont matter if its above or below the oil line in the sump.
barryogen wrote:True-No-Turbo wrote:how about just using a ball valve on the drain back from the can?, then it wont matter if its above or below the oil line in the sump.
hmm, if you had a light enough ball in the ball valve you could have it mounted upside down so that if there was pressure from below(ie:the sump), the valve would be closed, and when no pressure, it would open.
right?
jondee86 wrote:If the drain is above the oil level in the sump, crankcase pressure will
vent out the drain tube. If the drain is below the oil level, the oil will seal
the end of the tube, and prevent the tube acting as a vent. Oil from the
catch can will then drain normally.
Cheers... jondee86
True-No-Turbo wrote: Hey Slideways, you said your can was filling up about a litre, was that after a whole days racing or just after a few laps???
~SlideWays~ wrote:True-No-Turbo wrote: Hey Slideways, you said your can was filling up about a litre, was that after a whole days racing or just after a few laps???
Tank is 800ml and that was over flowing after less than 10minutes on the track eh, I thought I'd blown something!That was when running 17psi and lots of revs all the time.
What about yours? Was it more or less, interested to see if your breathers have much effect (with the baffling you said it still needed).
My sump is getting welded as we speak, cross fingers it works. Im just going to run a pipe straight from the drain hole in the catch can (have a threaded fitting for it now) and see how well it works. If it works well I'll get another catch can made up to suit (bigger too).
flygt4 wrote:i was barely able to get enough oil in the can to be measured with a dipstickthat was ~8laps at a time and working the engine petty hard. i even checked the oil level to make sure there was some in there
