help me build a shopping list
Postby gasman » Tue Oct 02, 2007 10:11 pm
so i saved up some cash now and its time to start ordering parts for my 4agte build during the summer holidays. what im going to do is a 20v bt head on a 8.9:1 4agze bottom end with shot peened rods with a link g3 with a 3 bar map sensor. would like to recon the ae101 gtz gear box so what will i need to order from mr revhead for the gear box and for the engine build?
i want to run a 3" stainless exhaust and 2.5" stainless intercooler piping. what grade stainless would be good for the application but still easy to weld?
"What can possibly go wrong?"
gasman
Postby matt dunn » Tue Oct 02, 2007 11:11 pm
From toyota,
Rod Bolts
Head Studs
Engine gasket set, (use a BT one them you get the head stuff,
as the bottom end is all the same anyway)
Pistons and Rings,
bearings if your replacing them.
Postby escortman » Tue Oct 02, 2007 11:55 pm
i assume u want to run quite high boost if ur gona use 3bar map sensor
matt dunn wrote:From toyota,
Rod Bolts
Head Studs
Pistons and Rings,
so wouldnt it be better to use arp rodbolts and trd metal headgaskit?
4x4 toyota blizzard offroader
escortman
Postby matt dunn » Wed Oct 03, 2007 1:33 am
escortman wrote:i assume u want to run quite high boost if ur gona use 3bar map sensor
Rod Bolts
Head Studs
Pistons and Rings,
If ya want,
thats what I run, All toyota stuff, and i run a 5 bar map sensor.
Three bar map sensor only handles 22 psi.
Postby escortman » Wed Oct 03, 2007 7:04 am
ook haha fair enuf
escortman
Postby d1 mule » Wed Oct 03, 2007 11:19 am
i used ACL "Race" big end and main bearings, toyota rings, head gasket and bolts. but i didnt really care that is what i could get cheapest with various connections etc.
d1 mule
Postby IH8TEC » Wed Oct 03, 2007 12:08 pm
acl bearings for me, arp headstuds and rod bolts. std headgasket as well, and holding together with 25psi
as matt said, need 5bar map sensor to go over 22psi.
regards gearbox, pull it apart, i put new genuine toyota 2nd, 3rd, 4th synchros in mine, didn't need anything else
think my exhaust is 302 or 304 stainless,
Postby bluemaumau » Wed Oct 03, 2007 5:50 pm
good info there brendon.
my 4agte:
acl race mains and bigends,
arp head and rod bolts
.8mm trd metal HG
are you building the engine?
my builder told me that its common for rod caps to distort when pressing in arp rod bolts, hence the need for a crank grind which = oversize bearings, dont buy anything until your engine builder tells you he needs it, as you may need oversize bearings or pistons
Postby flygt4 » Wed Oct 03, 2007 6:04 pm
if you're doing the gearbox get new synchros.it may pay to invest in tracking down the shorter gears that barry is using as 3rd gear is stupid long on the gtz gearboxes.
TRD 0.8mm headgaskets are really good, its just one less thing to worry about.
have you considered fabrication of an inlet collector?
consider your power level and whether you need a wanky clutch/PP now rather than later? allow $500-800 for that
flygt4
Postby gasman » Wed Oct 03, 2007 6:18 pm
flygt4 wrote:if you're doing the gearbox get new synchros.it may pay to invest in tracking down the shorter gears that barry is using as 3rd gear is stupid long on the gtz gearboxes.
i got an intake plenum made up similar to barry's and i got pretty much a brand new clutch from my old 20v engine, a exedy 4 puck one but im not too sure if it will work with the e58 box unless i run the 4age flywheel and get a new clutch plate that will fit the input shaft to the box.
how much are synchros worth? easy enough to install yourself?
bluemaumau wrote:are you building the engine?
i was going to build it my self but night get an engine builder to do it and just supply all the parts. how much roughly would this cost?
gasman
Postby bluemaumau » Wed Oct 03, 2007 6:24 pm
i think its worth it man, i wanted to do it myself, but theres just alot of little shit to get right, it would be better to learn to build a engine if it was a 4k or 4age, but a 200kw 4agte is probley not the best idea for your first.
ill tell you the costs when im finished,
Postby IH8TEC » Wed Oct 03, 2007 7:30 pm
bluemaumau wrote:i think its worth it man, i wanted to do it myself, but theres just alot of little sh*t to get right, it would be better to learn to build a engine if it was a 4k or 4age, but a 200kw 4agte is probley not the best idea for your first.
my thoughts exactly :)
synchros were either 60 or 80 each i think, email warrick, it should be in that range give or take $15.
Postby Adoom » Wed Oct 03, 2007 8:21 pm
matt dunn wrote: only handles 22 psi.
LOL!!! 'only' 22psi!!
Adoom
Postby IH8TEC » Wed Oct 03, 2007 8:38 pm
any less and your missing out :lol:
Postby escortman » Wed Oct 03, 2007 9:49 pm
My total cost
tank cleaning block, crank, rods = 100
rebore = 134
fit & hone bore L/E bushes = 76
crank regrind pins, mains & polish = 175
balance crank, flywheel, pistons, rods, clutch assembly etc = 280
skim the head = 52
mount & align rods = 42
fit water plugs & paint = 35
assemble short block = 400
spark erode balls & tap thread = 180
hardness test both my heads = 60
fit rodbolt & resize = 200
cracktest crank = 56
cracktest 4 rods = 40
deck the block = 70
trial assemble for deck height & rod to block clearance = 150
clearance grind block = 80
gudgeon bushes = 40
7 frost plugs = 10
packing & freight = 41
all up just under 2500 incl gst
thats excluding
aries pistons = 800 with free smallport block, rods and crank
trd 0.8mm metal hg = 120
arp rodbolts = 120
acl race big and main bearings = 115
headset = 100
conversion set = 30
thrust bearings = 17
headbolts = 40
proberly some other shit iv forgtten ahha
escortman
Postby gasman » Wed Oct 03, 2007 10:28 pm
things sure start to add up fast dont they
gasman
Postby escortman » Wed Oct 03, 2007 10:44 pm
hahah o yeh thats not even with the cost of turbo, manifold, oil cooler, remote oil filter setup, bov, fuel reg and pump, i stil need to get new intercooler and piping and get exhaust
escortman
Postby bluemaumau » Wed Oct 03, 2007 11:28 pm
yup people arnt joking when they say youll get no change out of 6k
Postby d1 mule » Wed Oct 03, 2007 11:40 pm
trd .8mm HG for turbo?? you raise the comp?? factory is 1.2mm aint it?
I ran a standard 7afe 0.6mm HG on my 7AGE with small port pistons about 12-12.5:1 comp ratio N/A POWER shame i sold it before i used it :oops:
d1 mule
Postby tsoob » Thu Oct 04, 2007 1:08 am
bluemaumau wrote:yup people arnt joking when they say youll get no change out of 6k
Man 6k would only be half way!!
tsoob
