Wheel Studs!!
Wheel Studs!!
Postby tsoob » Thu Oct 04, 2007 1:02 am
Help my new wheels wont fit the studs are too short, where do i got to get em to fit??
tsoob
Postby mjrstar » Thu Oct 04, 2007 8:03 am
Hey nick,
i have found repco have a pretty good selection of different length wheel studs.. although i'm sure there are places out there that won't try and rip you off so much..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby bluemaumau » Thu Oct 04, 2007 10:21 am
hang on, have you changed your wheels or hubs recently?
if its your wheels the stud/nut holes could be smaller meaning you need to get thinner wheel nuts (i had this problem)
Postby tsoob » Thu Oct 04, 2007 10:36 am
new wheels have had 17s before on there tho
tsoob
Postby ~SlideWays~ » Thu Oct 04, 2007 11:39 am
Either fit longer studs or you may need internally wrenched wheel nuts and/or a different tapered end.
~SlideWays~
Postby bluemaumau » Thu Oct 04, 2007 1:12 pm
are the holes smaller?
Postby thegreatestben » Thu Oct 04, 2007 1:23 pm
We had this problem with a set of 15" for an AE92 corolla. Had the right wheel nuts and everthing, but could only took 1.5 turns until they were done up tight.
Wasn't going to risk that and CBF changing the studs so they were sold.
thegreatestben
Postby tsoob » Thu Oct 04, 2007 2:20 pm
will not be selling the wheels i have just painted them and they look awesome, will prob change the studs have tried a few nuts and still no joy get mabey 4 turns and thats it.
tsoob
Postby darkwolf » Thu Oct 04, 2007 7:06 pm
Who makes the wheels. The enkei's that I bought needed specific Enkei nuts. As mentioned before they are internally wrenched and a fuggly ucker to put on. But nothing beats the real thing - trust me I had a wheel fall off trying alternatives.
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
Postby Cakky » Thu Oct 04, 2007 7:14 pm
to fit the bzg wheels to my corolla I used shank and washer nuts, work well.
Cakky
Postby strx7 » Thu Oct 04, 2007 8:20 pm
I had a similar problem on my AE104 project. I went to Y60 Safari wheel studs, which are 12 x 1.25 thread and longer so not only was there more length, there was more threads per that length too.......
Postby tsoob » Thu Oct 04, 2007 10:11 pm
they are advanti wheels im pretty sure ill need longer studs
tsoob
Postby mjrstar » Fri Oct 05, 2007 12:02 pm
you sure do...
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby tsoob » Fri Oct 05, 2007 12:33 pm
i got the back ones off easily but the front is proving to be a challenge, have a mate who can change the studs, where do i but studs from?
tsoob
Postby strx7 » Fri Oct 05, 2007 12:53 pm
a dismantlers or pick-a-part
Postby Ae92typeX » Fri Oct 05, 2007 6:29 pm
many mag shops, most car parts retailers
Ae92typeX
Postby tsoob » Sat Oct 06, 2007 2:11 am
how do you get the front hubs off? i have a 30mm socket now but still no joy just lots a swear words?
tsoob
Postby Ae92typeX » Sat Oct 06, 2007 10:38 am
a carefully placed/angled hammer behind. ideally a puller/impact puller, or at a pinch with the nut off, put wheel on with nuts as much as you can do up and leaver off. probably easier with cv out the way.
Ae92typeX
Postby Grrrrrrr! » Sat Oct 06, 2007 11:18 am
Be careful using hammers around hubs that have ABS rings behind them, some of those are damn brittle so one good wallop with a hammer and your up for a new hub.
Grrrrrrr!
