What should I replace along with my cambelt?
Postby ollieboy » Thu Oct 04, 2007 2:08 pm
I just want to double check I have everything written down before I order it.
Engine is 4age in '84 mr2 with about 205,000 kms on.
Reason for needing cambelt replaced is the tensioner bearings failed and the tensioner basically fell off.
So I obviously need:
Cambelt
Tensioner and idler
Think its a good idea to replace:
Cam seals
Waterpump
Thermostat.
Radiator Cap.
Anything else I need or you think I don't need off the list.
Ollie
ollieboy
Postby pc » Thu Oct 04, 2007 3:40 pm
also replace the crank seal while everything will be removed.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Mr Revhead » Thu Oct 04, 2007 4:25 pm
yes.
cambelt
tensioner
cam seals
crank seals
waterpump seals
drive belts
Postby ollieboy » Thu Oct 04, 2007 5:03 pm
Oh yeah forgot to list that. Sweet, you'll probably get an email from me in a couple of days Mr Revhead :)
ollieboy
Postby ollieboy » Tue Oct 09, 2007 9:39 pm
Sorry to bring this up again but I was just checking. Is it necessary to replace the waterpump or will it be fine?
ollieboy
Postby levinguy » Tue Oct 09, 2007 9:45 pm
i would,
do you really want to pull it apart again to change it?
remember if you leave its got to last another 100,000 k's
levinguy
Postby ollieboy » Tue Oct 09, 2007 9:47 pm
Cool, yeah I was sort of thinking I should anyway seeming its done a few hundred thousand k's anyway but didn't really know. Thanks.
ollieboy
