4age going very slow
Postby rwd_mayhem » Fri Oct 05, 2007 9:31 am
so i was driving all fine no problems, all of a sudden (i cant quite pin point when it started) something went wrong. its just really slow, it seem to idle fine, just when i take off it takes ages to get up to speed, im revving it to 6/7 just to keep up with grandmas in altos!
what are some possible problems?
current: 1975 Valiant Regel
rwd_mayhem
Postby Trls250s » Fri Oct 05, 2007 9:52 am
Is it bigport?
TVIS Solinoid could have died. Vaccum lines could have come off.
The first 2 places i would look.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Kender » Fri Oct 05, 2007 3:19 pm
Your mate's placed a block under your accelerator pedal? :lol:
Seriously though, is your engine getting enough fuel? Was it surging at any point? I've now had 2 fuel pumps die in my MR2s due to blocked pickup tubes.
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
Kender
Postby rwd_mayhem » Fri Oct 05, 2007 4:14 pm
yes it's a bigport bluetop tvis. and all the hoses to tvis are connected
its getting enough fuel, the plugs were all carboned up suggesting running too rich.
I used some sealwell cubes a while ago and now the water is all yuck, black, chunky and smells like fish lol. im going to put a radiator flush through it and replace the temp sensor, im thinking the water gunk has screwed the sensor maybe? causing it too run too rich?
rwd_mayhem
Postby gepsk8 » Fri Oct 05, 2007 4:54 pm
change tps, check map sensors got valcum & maybe try swapping it
gepsk8
Postby Ae92typeX » Fri Oct 05, 2007 6:34 pm
run the codes before you start replacing stuffs.
Ae92typeX
Postby matt dunn » Fri Oct 05, 2007 8:50 pm
cam timing?
Postby rwd_mayhem » Sat Oct 06, 2007 8:37 am
Ae92typeX wrote:run the codes before you start replacing stuffs.
i don't have a engine light so i don't know how to get the codes?
gepsk8 wrote:change tps, check map sensors got valcum & maybe try swapping it
cheers, will try sometime.
matt dunn wrote:cam timing?
i haven't touched anything though, so how would it change so drastically?
rwd_mayhem
Postby method » Sat Oct 06, 2007 11:12 am
Well what does it feel like when accelerating?
If you give it half or so gas does it go as well as if you give it full gas?
Does it feel like it boggs down when you put your foot down?
Is it jerky?
I had a problem with my car bogging down and running super rich when i put my foot all the way down. It was fine up in higher rpm like 6 - 8k.
I think it was my FPR causing the problems.
PICS UPDATED DAILY
method
Postby themaleman » Sat Oct 06, 2007 11:45 am
check knock sensor hasnt loosend its-self, mine kept cumming loose and it triped the engine check light and the car woudnt boost
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby gepsk8 » Sat Oct 06, 2007 1:14 pm
bigport bluetop tvis, don't run knock sensors.
gepsk8
Postby lucasthefallen » Sat Oct 06, 2007 1:18 pm
checked your compression?
Need Service or Repair work done? send me a PM
lucasthefallen
Postby KinLoud » Sat Oct 06, 2007 5:32 pm
Cam timing - if the cambelt has lost a couple of teeth it can skip on the crank pulley or a cam wheel and so get out of time.
Ken
Ham
021 408 863
Postby matt dunn » Sat Oct 06, 2007 8:23 pm
KinLoud wrote:Cam timing - if the cambelt has lost a couple of teeth it can skip on the crank pulley or a cam wheel and so get out of time.
Ken
Ham
021 408 863
they dont even need to loose teeth, if the belt looses a bit of tension they can jump teeth,
Postby 85AW20v » Sat Oct 06, 2007 11:12 pm
Changed your air filter lately? Any smartarse "mates" who could've stuffed your intake with a rag?
See ya
Simon
85 MR2 20v
85AW20v
Postby rwd_mayhem » Sun Oct 07, 2007 3:56 pm
so today i played around a bit with it. put a brand new temp sensor in, tried swapping map sensor, fuel regulator and TPS. changing map sensor did nothing. changing fuel regulator did sweet $&#$% all. the TPS is making it worse now though, because i dont know how to put it in properly. still slow as.
if i do slowly put my foot down rather than just planting it it does make it a bit better but not much.
it goes all good in the higher revs though once tvis has kicked in.
rwd_mayhem
Postby lucasthefallen » Sun Oct 07, 2007 5:26 pm
blocked fuel filter? bad compression? block air intake?
lucasthefallen
Postby Mike- » Sun Oct 07, 2007 7:13 pm
youll need to set your tps correctly or it will run like a dog (not a greyhound either), then set the timing.
mine had the same problem your describing till i did this.
Mike-
Postby rwd_mayhem » Mon Oct 08, 2007 12:24 pm
how do u set tps?
when i put it on where do the prongs line up to?
when i turn it should it turn the throttle body butterfly? or just spin easily?
rwd_mayhem
Postby bluemaumau » Mon Oct 08, 2007 12:51 pm
