touge rolla wrote:These videos are rigged advertising, and it would be possible to compare any two BOV's against each other and create whatever result you please all with a simple spin of a spanner
http://www.youtube.com/watch?v=8-JTfgpF ... ed&search=
True-No-Turbo wrote:Ive seen a comp wheel nut spin off on a TD06 once, couldnt figure out how the hell it happened, until someone told me that comp surge was the cause.
KinLoud wrote:I'm really puzzled???
Stupid blow off sound = compressor surge?
So if you don't have a blow off valve it won't surge? Well I learn something new every day!
KinLoud wrote:Are we talking about compressor surge or blow off valve surge? Big difference!!!
One affects the sound and the other affects power! Hmmm I wonder which one I'm more worried about?
True-No-Turbo wrote: Compressor surge is caused by a blow off valve not releasing pressure fast enough when the throttle snaps shut, the pressure has nowhere to vent so backtracks back past the comp wheel, stalling it, and out through the air filter (ie - cha cha cha cha).
I know alot of people think this is the blow off valve making the noise, but its NOT, its actually the BOV not doing its job. If its working correctly you will only hear (psssssh) as all the air is exiting out the BOV and not back through the turbo housing.
lol now Im getting confused , maybe your understanding of comp surge differs from my understanding of what it means?? so what your saying is that people are getting confused between the two meanings? as in comp surge is actually BOV surge? and comp surge is terminology only used on a compressor map???... is that correct??
I can tell you from experiance the ssqs are crap, been there tried that.
touge rolla wrote:edit: mild compressor surge can be hard to detect with standard air box
fivebob wrote:What most people call surge is actully valve flutter, and in fact is the valve doing the job it was designed to do. True compressor surge sounds totally different, and it's not something you'd ever confuse with valve flutter if you'd ever actually heard it
Users browsing this forum: No registered users and 34 guests
