Caldina GT-T catch can
Postby Santa'sBoostinSleigh » Thu Oct 18, 2007 11:26 am
is this the correct setup for a catch can or am i going to lunch my motor?
there is alo a bigger hose on the other side of the motor (air box side) which must be around 17-19mm ID? this pumps out way more air from the head and feeds it into the air box (compared to the small line)
i am planning on plumbing this into a catch can also, but have to figure out how to get a big hose working with it.
i assume both of these are ok to go into the same catch can and should be vented to atmosphere via a mini breather filter?
the hose with the bolt into it in the pic above goes into the intake plenum, and now is obviously blocked off
any comments?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby 1eyed » Thu Oct 18, 2007 3:30 pm
That small hose should go into the can, from there back into where-ever it normally goes (i.e. into the air intake). It's only slightly oily air, strip the oil mist out of it, and burn the rest.
No idea about the other hose. Perhaps a photo?
1eyed
Postby AW11 Turbo » Tue Oct 23, 2007 12:42 am
i made it this way:
Image Image Image Image
AW11 Turbo
